Question about B&K Mueller/B & K 450-032 90 Red Brass Threaded Reducing Elbow
I need to find a replacement washer for an outside hose bib. On the outside of the assembly it says ASSE 1019 UPC and on the washer it has 00 on the top and 7148 on the bottom
You can get a 00 washer at plumbing supply or sears hardware. Lots of places Home Depot
Posted on Sep 25, 2009
When I hook my cold water up to the back of the washer it leaks. Its not the hose its the actual bib on the back of the washer. Is this replaceable and where do I find one?
if ur talking bout the water inlet valve the whole thing needs replacing. however highly unlike it has any parts that would leak? other than someone putting on the hose improperly and damaging the threading? perhaps u may want to take a closer look at ur hoses and make sure it has the rubber seal in side it?
Feb 21, 2015 | Maytag Centennial Series MVWC200XW
I replaced the hot & cold water valves on my LG Washer/Dryer .Now it just humms and no water goes into the washer..What can cause this problem?
have you tried both the cold and hot?hot only has one solenoid while the cold has three.just because it is a new part dose not mean it is not mean it is a good part.try this,turn off the cold and hot water,remove the cold hose from the washer and put it in a bucket and turn it on at the hose bib.if you do not get water,you may have a screen in the hose bib end of the hose.if no screen on that end you may have a metal fitting rusted up just under the hose bib.check the hot side also.hope this helps,if not repost and i will try to dig deeper.thanks
Mar 15, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Black slim in hot water
SOUND LIKE YOU NEED TO DRAIN AND FLUSH YOUR WATER HEATER TANK. THERE IS A HOSE BIB AT THE BOTTOM OF THE TANK. RUN A HOSE FROM IT TO A DRAIN OR OUTSIDE. SHUT OFF THE COLD WATER INLET VALVE AND OPEN THE HOSE BIB. OPEN HOT FIXTURES IN THE HOUSE.CHECK THE DRAINING WATER FOR CLARITY. IF CLEAR OPEN THE INLET VALVE AND LET IT FLUSH(YOU MAY GET MORE DISCOLORED WATER, RUN UNTIL CLEAR). SHUT HOT WATER FIXTURES, CLOSE THE HOSE BIB AND LET TANK REFILL.
Mar 30, 2013 | Water Heaters
Stripped screw hosebib outside spigot
its probably cheaper and easier just to change the bib....but if you have a easy out you can drill and remove the screw that way and then go to hardware and get another screw and get parts...
Jul 15, 2012 | Dmm Free Standing ADA Compliant Valve ...
Leakage from the garden hose connection along with connection to the pressure washer.
The female hos bib connection should have a typical hose washer inside.Often you can't tighten the nut tight enough without this washer, to keep it from leaking both from the hose, and the rest fo the fitting into the washer.
Jun 14, 2010 | Stanley 1600PSI Pressure Washer w 20ft...
How to reconnect the heater hose from the motor side of the firewall on a 1997 ford thunderbird 4.6 v8
Provided the hose bib for the heater hose is still sticking out of the firewall the hose slips over the bib and then a hose clamp is tightened over the hose. But it's possible that the bib is broken off and then heater core is going to need to be changed
Jul 02, 2010 | 1997 Ford Thunderbird LX
How to properly install and insulate a new hose bib
Get yourself what is called a "Frost Proof" hose bib. This puts the shutoff valve in the assembly well inside the cellar so insulation will not be a concern. I believe they come in two different lengths so get the longest one. Make sure you have a shutoff installed in the supply pipe (it should already be there) so you can shut off the water completely to the hose bib. Hope this helps.
Jun 08, 2010 | Plumbing
Leaking outdoor hose bib
ok this is an easy one.  you have what is called a  frost free hose bib.  this is split or has a hole in it after the seat.  the seat is inside the house wall.  you need to cut off the copper inside the house and replace the valve .  if it is not a solder joint than have someone hold back on the copper on the inside and you should be able to spin it off and replace it.  P.S if this is the case make sure you use T-tape on the threaded conection
Jun 21, 2009 | Plumbing
Leaking outside frost free hose bib
take it apart and put some trflon tape on the threads
Jun 01, 2009 | B&K Mueller/B & K 450-032 90 Red Brass...
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
8 out of 10 times the hose screens are clogged.  1. Remove the hoses from the back of the machine, but leave them connected to the hose bibs.  2. Remove the screen from the hose (it may be stuck at the back of the machine) (This is where deposits usually build up.) 3. Aim the hoses into the drum or a bucket and turn on the bibs. 4. If you don't have a full flow of water coming out of the hoses you will need to remove the hoses from the bibs and reverse the process. Good Luck.
Feb 23, 2009 | Kenmore 22422 Top Load Washer
B&K Mueller/B & K 450-032 90 Red Brass Threaded Reducing Elbow Logo
911 people viewed this question
Top B&K Plumbing Experts
Tom Chichester
Daryl Gleaton
Joe Ball
Joe Ball
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
