Question about Dell 5100cn Laser Printer
The images seem to be light and not sharp when printing. Full Color seems to be ok
  • charlotte574 Sep 25, 2009
    I changed the black out. The color on the images are light especially with yellowish tones
    President:
  • 1,653 Answers
This is most likely to be an issue with the black cartridge as the colour prints OK. Do you have another one you could try?
Posted on Sep 25, 2009
  • Karl Wright
    Karl Wright Sep 26, 2009
    *On a scale of 1-10, how often this problem occurs (10 being most likely).
    Cause
    Solution
    How common*
    Defective engine controller board or high voltage power supply.
    Replace the engine controller board and/or high voltage power supply.
    8
    Defective laser/scanner
    Replace the laser/scanner
    6
    Poor contact to the engine controller board
    1. Ensure that the drum ground spring is connected to the engine controller board correctly. 2. Clean the contacts if they are contaminated. If the problem remains after cleaning, or parts are damaged or deformed, replace them. 3. Replace the engine controller board, if necessary
    6
    Toner cartridge is low
    Replace the toner cartridge
    5
    Transfer roller is defective
    Replace the transfer roller
    Wrong toner density setting
    From the print-quality menu on the control panel, adjust the toner density setting. Make sure EconoMode is off
Why is my printer not printing the right color? its very faded
Is your printer set to Economode in the printer settings? It may be and so its printing at low quality.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
My printer is Fuji xerox 1250, Recently i have a problem for the color issue, we tried color Calibration, We changed drum, we even reset to manufacturer default setting (by press 0+ green button and...
It seems your yellow color is not function correctly. Need to check yellow color feed and its linkage to deliver ink to your paper. Looks like it almost clog up that cause very light color in your paper. Again please check completely your color feeds.
Regards,
Dec 15, 2010 | Fuji Office Equipment & Supplies
Print quality poor for mp780. Had s800 which
There seems to be a calibration problem. Follow the calibration test from the manual.
If you are using original cartridges, go to canon for repair.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Canon PIXMA MP780 All-In-One InkJet...
The red light has come on - mid-way through printing, and nothing I do seems to rectify the problem. It won't print. Just got the blue and red lights on all the time
Many things can cause that, toner box full, fuser not heating, paper empty, toner empty, paper scraps inside, imaging belt used up, If the owners manual doesn't help you locate the problem you may need a shop. Samsung customer support can help too, you'll find their number on line.
Jan 25, 2010 | Samsung CLP-315W Laser Color Printer
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Dell 5100cn Laser Printer Logo
185 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
