Question about Garden
Karcher K386M-I was using the washer and the pressure hose popped off the outlet of the unit. I put it back on and it popped out again. The second time I noticed the oring was gone. It was on there when I first put the hose on. Why does the pressre hose pop off.It was on tight?
  • 42 Answers
SOURCE: Karcher high pressure hose pops off high pressure outlet.
Try one of the products from your local DIY store, i,m talking about the two part putty that you mold with your fingers, can be drilled tapped and can do amazing bodges, plumbers are never without it! Good Luck - the Yeti
Posted on May 17, 2009
  • 174 Answers
SOURCE: poor pressure
i had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
Posted on May 31, 2009
  • 72 Answers
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
  • 88 Answers
SOURCE: Karcher K2.19 Pressure Washer - Hose Coming Off
yeh this is what happen if you remove the yellow cover and you will see the metle u clip that is all that part holds on. you will needa new one from your local pressure washer supllier
Posted on Jan 20, 2010
  • 15 Answers
SOURCE: Water is leaking from under the chrome piece
Plastic Pump Manifold is cracked.
Can be replace at a local Karcher Service Center, or if you are mechanically handy. Replacement Manifold Complete, is available from www.karcher.com.
If it is under 1 year old, and under warranty Karcher will replace if you have a Receipt proof of purchase.
Posted on Jul 14, 2010
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Power hose keeps popping off
If it is popping off from machine side, the outlet thread could be damaged. This both on the machine and on the hose.
If it is popping out at the gun end, there must be a clip that holds it in place missing. This I am assuming that you have the right hose for the right machine. Using hoses not intended, will cause a lot of problems. Even actual hoses, they never should be modified.
Regards.
MG.
Oct 01, 2014 | Karcher K2.26 Electric Power Washer
If a washer not used for a few years would that cause any problems
Hi and welcome to FixYa, I am Kelly
The seals do have a tendancy to harden / dry out or... corrosion prevents the unloader bypass valve from moving / operating properly. I recommend you put a little oil (2 oz maybe...) through the unit on purpose via the inlet water connection. Then connect your water hose and force the oil though the unit with the air in the water supply hose while it purges. DO NOT turn the unit on until your sure the water supply hose has purged out all air. Then turn on the unit making sure that you cycle the wand trigger rapidly for a few minutes by cycling the trigger until the high pressure hose is not so rigid then let the high presure hose charge fully again. Cycle trigger wait, cycle trigger wait. 1 second bursts until you get full pressure. Then use normally. This usually wakes up pressure washers that have been resting :)
Thanks for choosing FixYa,
Kelly
Apr 18, 2011 | Karcher Garden
My Karcher 720mx moter is working fine but i have no water pressure coming from pump
hi put some silicon spray in inlet and outlet then reconnect hoses what is going on is when you store it the seals start to dry out.........
Jan 13, 2011 | Karcher K3.68MR Electric Pressure Washer
My karcher has a hole in hose close to unit can i cut it and put back in
if the hole is in the gun hose then no.
it will need to be replaced. try bunnings warehouse.
you may need to purchase the gun & hose together.
Dec 11, 2010 | Karcher PSI Electric Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
May 17, 2009 | Honda Karcher G2400HH-R Pressure Washer
Karcher high pressure hose pops off high pressure outlet. I think it is stripped.
May 17, 2009 | Karcher PSI Electric Pressure Washer
How do i connect the hose to the karcher k399 handle
Pop out the plastic tab at the base of your gun (use point of screwdriver/knife).
Then push the hose connection into the gun and push the plastic tab back into it's slot. This will hold the hose in place.
Jul 02, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off...
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Jun 19, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
296 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
