Question about HP Pavilion dv6000z Notebook
I have a hp pavalion dv6000. It is not coming on.
I have a hp pavalion dv6000. it was on when I left for work. But when I came back from work I met it off and it was still plug in to the wall outlet. I try putting it back on and there was on power entering it. I notice that the power supply was damage. so I use another power supply from the other hp laptop wiht the same 18.5v that is working fine on the other laptop and I am still having the same problem. can't come on, not even receiving power. can anyone please help me
  • 39 Answers
There is a motherboard issue with this model. hp did offer a free repair on the motherboard.If you still have warranty, then you will need to contact hp to get your laptop motherboard repaired. they also offered an extended warranty due to this problem, you will really need to contact them ASAP so that you don't loose out, cause the motherboard replacement cost is around $600USD.
Posted on Sep 25, 2009
Hp pavalion dv6550 runs on charged battery but not on adapter and does not charge the battery either. When the AC adapter is connected the blue light comes up so I'm assuming it is powered and con
Try another cord/charger with the EXACT same power specs as the original. Has the AC jack in the laptop been damaged, loose connection, due to pulling on the cord while plugged in? Try to wiggle it when plugged in to see if there is any connection. The AC jack may need replacing, if your lucky.
Apr 07, 2013 | HP Pavilion Computers & Internet
Tip
My Hp dv6000 laptop battery is not working?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} e4f2593.jpg
Your battery is likely dead. Batteries over time lose their charge and eventually fail completely. I had a DV9000 laptop and after about a year or so it would report the battery was fully charged but it would only last 15 or so minutes before dying completely. Yours has probably met this fate.
Also, the HP DV6000 and DV9000 series of laptops (some batches) had defective batteries out of the box that there was a wide spread recall on (although HP did not publicize this much unfortunately so many that actually were affected never was notified of it, you might want to check HP's website to see if your products SKU was part of the recall.
But if your system is out of warranty they probably won't honor the recall at this point.
It might just be time for a new battery. HP DV6000 Battery
on Mar 27, 2010 | Computers & Internet
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
Just replaced power supply unit from a 250 watt to a 480 watt and now computer comes on but will go into power saving mode instead of booting up and keyboard doesn't stay lit like it used to.The system is...
Which power supply went bad? The 250watt or the 480watt? If a power-supply goes bad (dies), it generally takes some (if not all) hardware with it.
Jan 05, 2010 | HP Computers & Internet
Hp dv6000
dear problem in prossear fan and hit sink jus chenge the hit sink and fan after working fine
www.compudesk.in
Jun 22, 2009 | HP Pavilion dv6000t Notebook
Hp pavalion tx2170ee tablet laptop tablet not working
To solve Hp pavalion tx2170ee tablet laptop not working we have hp tablet support phone number +1-800-281-3707 Chances are pretty high that your problem would be resolved over the phone itself It's excellent. 1 800 281 3707 HP Tablet Support Phone Number HP Tablet Repair
Apr 20, 2017 | WalkAbout (37429123225)
Hp pavilion dv6000 screen goes blank 5 minutes after startup
i cannot install win xp on my hp pavalion it is already contain win vista and hard disc is SATA type give me a solution
Sep 08, 2008 | HP Pavilion dv4000 Notebook
Wecam 1.3mp builtin for hp pavillion dv6000 found not working the day i bought the machine
Hi I have Hp pavillion dv6000. When am using yahoo msnger or msn ..the web cam not working. There is one message coming Your web cam is not connected. Please give me a solution for this....
Thanks
Simon
Jul 15, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
