Question about Kenmore Refrigerators
Freezer door opens each time we close refrigerator door
Our freeze door on our side-by-side, opens each time we close the refrigerator door
  • 146 Answers
This is an easy one to fix - at the bottom of your unit you have 2 adjustable wheels you can turn to raise or lower the unit. What you need to do is turn those clockwise which will raise the front - what you want is to have it slightly tilted to the back. As a test you can open your door 45 degrees and leave it - it should be able to close on its own.
Posted on Sep 25, 2009
I have kitchen aid superba the icemaker works fine, except at the door where ice is dispensed the unit freezes up the ice crusher area like there is an air leak in the door somewhere which allows warm air...
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again.
Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
Oct 16, 2013 | KitchenAid Superba Architect KSCS25INSS...
The freezer door will not close tight
Hello, check the freezer sliding door rail. Removed everything in your freeze then gently slide out the freezer door. Check the bottom of the freezer for food items that may have dripped into the bottom of the freezer. Now, the check the roller rails along each side of the freezer there could have been widget that got smash by the roller on the freezer door, if you find this smashed widget--he not drunk--he is dead. Scrape the those roller rails and clean the and get all the globs,ice cream, widgets, pieces of other different types of freezer flub.
Next, set a level on the freezer door and see if the bubble is point forward, if not then screw up the front two leveler in the front of the freeze--one on each side in the front of the freezer/refrigerator. I hope this help you. GB...stewbsion
Oct 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
The ice cube maker makes ice ok but the ice crusher is not crushing properly. The grinder area(teeth) seems to keep geting frozen (clogged) with ice.
The most common problem with this is the door/flapper is not closing snuggly. Usually a piece of ice holds it open but if this is happening all the time make sure the little ice door/flapper is closing all the way open the door and push it open and see how it is closing. If there is not water freezing on the left side of the freezer under the icemaker its self you have to have air getting into the freezer and usually its the ice door. good luck
Aug 15, 2010 | Whirlpool GS6NBEXR Side by Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
My Whirlpool side by side keeps freezing on the regular side.
your damper door is most likely frozen in the fully open position,thaw it out if iced up,then adjust cold control to see if it closes,the door is inside between the refrige and freezer compartments,also if this happens again check the door seals to make sure they are sealing good and not letting in warm air that can condense and refreeze this door
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side by side fridge freezer. The fridge compartment is freezing the food. can you help?
check thermostat for loose or damage connection but check the damper/blend door -located -in freezer where the fan is located and in the fridge where the air blows in is a duct and inside the duct is a damper -door that opens to let in cold air from freezer and closes when the fridge reaches temp some times ice or a piece of debris restricts it from fully closing or the unit gets stuck open--
Nov 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezing in refrigerator
Inside the fresh food compartment on top left there is something called an air baffle. It runs between the freezer and fresh food compartment and its purpose is to electrically control the amount of cold air coming from the freezer. Sometimes they freeze open and will not close. So you may need to turn off the refrigerator during the time you examine it. Look for ice blocking the movement of the baffle damper. Sometimes just one time clearing the problem is all you need to fix it. Let me know what you find and if you are able to get it going again, Thanks, Sea Breeze
May 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Whirlpool refrigerator side by side Ice control
its a defrost sensor that reads the inside temp of your freezer so it knows when to defrost itself.you need to close it so it wont allow th freezer to freez up.
Oct 12, 2007 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
63 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
