Question about Frigidaire GLTF1040A Front Load Washer
Door seal wire spring replacement
The wire spring on the drum end door seal came out along with the seal. How can I put the seal and spring back on without removing the rest of the seal?
  • 1 more comment
  • Anonymous Mar 25, 2009
    Ugg... i have the same problem
  • Anonymous Mar 22, 2014
    I think the suspension spring has come out of retaining hole
    is it suspension spring
  • 262 Answers
Oh my there is no way but to take front off and you need special tool to hold the spring in place this may a job for a tech IT IS NOT FUN!!!! but there is NO WAY to put spring back on Trust me Ive tried Good luck
Posted on Dec 17, 2007
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
Replace door seal
its not to easy to do but,,,
look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
and then job a good un?,,, not easy a,,well i did tell you this!
Jul 12, 2010 | Frigidaire ATF6000ES Front Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Door seal on servis M9824W has been removed to access bits in the drum. how do i refit it.
The door seal, the hot air inlet and door seal overflow pipe had been disconnected from the drum. Main problem was access to reconnect the door seal overflow which is a very short pipe section going to a small hole in the front of the outer drum and access very difficult.
First remove the top cover of the machine. Two very long screws and two self tappers at the top rear of the cover.
Make sure that the hot air duct is disconnected from the heater outlet and remove the separate plastic duct which bridges between the heater and the hot air duct in the seal.
In this case the door seal had been pulled off the outer drum and the retaining coil spring had also been recovered. If the seal is still in place there is a "handle" moulded into the seal which might assist in starting the removal of the seal.
Remove the outer seal from the front panel of the machine by easing out the wire and spring retainer which can be accessed by the door hinge. Carefully remove the door seal from the front panel and remove it.
Check for damage and if necessary get a replacement.
To Refit
Push the door seal into the machine loosely and connect the overflow pipe (very difficult access). I leaned the machine on its back to make access a little easier.
Next carefully fit the seal onto the outer drum starting at the bottom by the overflow pipe. Be very careful not to disturb the previously fitted overflow pipe. Make sure the seal is correctly fitted over the retaining flange on the drum.
Next fit the retaining spring by threading it behind the overflow pipe and into the recess on the outside edge of the seal, connect the two ends of the spring together to form a circle and carefully stretch it into place around the door seal. Take care at the top to make sure it goes behind the hot air inlet duct.
Apply a little gasket compound onto and under the lip of the overflow pipe where it enters the outer drum at the bottom (a bit messy and awkward).
Next fit the seal to the front panel of the machine ensuring that the tabs on the seal are aligned with the markings around the front edge of the door aperture.
Fit the wire and spring retainer such that the coil spring sits on the left side of the opening within the moulded recess in the door seal.
Now refit the hot air inlet duct between the heater unit and the door seal ensuring that the parts are it the correct position and the two lugs are stretched over the the small spigots on the heater body.
It took 4 hours to do the job but that included the learning curve. Reckon it should only take an hour if two peaple are available when fitting the inner and outer seal retaining springs.
Nov 03, 2009 | Washing Machines
How to replace seal between door and drum
1. Unplug from mains electricity.
2. Pull machine out from wall carefully.
3. Remove screws in top corners (that are holding down the top panel of the machine) at the back of machine.
4. Remove top panel of machine (slide it slightly in the direction of the back of the machine, it just lifts off).
5. Remove the detergent drawer (pull it right out and put it to the side)
6. Remove the two screws at the top of the gap where the detergent drawer goes in
7. Remove the two screws at the top, front of the machine
8. Now lift out the panel with the control dials on it (etc.). Careful here, you don’t have to disconnect all of them, you should just be able to put this to the side with all the wires still connected.
9. If the old door seal is still on (if not go to 10):
a. Look carefully at the arrangement of the rubber at the lip of the drum and the door rim (you’ll need to know so you can put the new one on)
b. The outer rim is sealed in by a circular wire linked by a small spring. It’s a bit tricky but you can unhook the spring from the wire (using a blunt knife to lever it out – careful not to damage the rubber) to remove it.
c. The inner rim is sealed with a larger circular spring. You can either lever this out with the same blunt knife, or just pull hard on the rubber to get it out, and the rubber off.
10. Now position the new rubber door seal between the drum and the door
11. Grip tight around the outside and inside of the rubber door seal and attach it to the lip of the drum. This is the trickiest bit, and seems impossible but it is doable. The key here is that once you have a bit of it on, the rest will slip on as you work around it the circle. Even at the bottom and sides where your hands can’t reach it should slip on nicely. It ain’t easy, give it time.
12. Now get the spring on the inner rim to seal it (again, not easy, give it time and muscle – you need 3 hands for this!)
13. Then attach the outer rim to the lip of the door rim, and hook the metal wire back in place with the little spring.
14. Put the panels and screws back in in the reverse order to how they came off/out. Make sure there’s no parts left over, ey!
15. There you go – plug it back in and run a test wash. Check for leaks
Oct 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
Rubber door seal replacement on my Front Load Washer
Jul 06, 2009 | Whirlpool Washing Machines
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Replace door gasket
It sounds like you have left the spring on the inside lip of the door opening when you removed the old seal,
You will have to take the seal off again and feel for the spring on the lip of the front of the drum, you will find it easier if you have something to hook it out with,it is fiddley, but you must get the spring out, or the seal will not stay on
Refit seal as before, and double it back inside the drum,then fit the spring in the groove that you can feel on the lip of the door seal. Work the spring all the way rond feeding it into the groove as you go round, you will find it a lot easier if you have someone there to hold the spring as you are are fittingit, it is very fiddley, stick with it!!!.
Plz rate this solution .
Dec 19, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How to replace rubber door seal
when you open the door you find a this wire clamp round the edge of the door seal, this just comes off with little force, this has to go back on obviously so don't bend it, the door seal just folds back on itself, the clamp on the drum end is often a large thin spring, and that also just pulls off, the seal then also comes away with a little pull, the new seal is fitted with the groove either side of the drum lip, then the spring is put back, take note how all is removed before working on it? the front of the seal is fitted then the wire, close the door to check a tight but easy fit, check for any leaks and correct fitting before leaving machine unattended any time, sound worse that what it actually is, if i have helped rate me,
Sep 16, 2007 | Bosch WFR 145 Front Load Washer
Frigidaire GLTF1040A Front Load Washer Logo
230 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
