Question about Dual Electronics CECT P168 Cellular Phone
I' m trying to install a device in my usb and my
I'm trying to install a device in my usb and my computer don't recognize the device! And my computer is windows vista what can I do? Or if anyboby nows if I can download a software for it? thanks!
    Problem Solver:
  • 9 Answers
Most manufactures have free drivers and software on their sites. Just Google it and go from there. BTW-
most usb devices have you install the software first before plugging in you device. Good Luck, I hope this helps.
Jimzer
Posted on Sep 25, 2009
Winxp sp3 andwin7 cannot recognized its USB adapter saying that it is an unknown device, i've tried to remove it from device manager and reboot, i also tried to update the driver through windows update...
The easiest way to figure out what is going on is to try the adapter on a different computer. If it is still good it will be detected. Usually when a usb device fails it may be recognized or is recognized only as a usb device but it will not work. You don;t have to install any drivers just to test this on another computer unless you want to make sure it is fully functional. It is also possible that the usb ports on the computer are not working or one isn't. Simpley use on of the other ports.The usb port controller usually operate a pair of usb ports so try all the ports. You may get a problem with one port or pair but rarely all at the same time.
I think you will find that the adapter itself is your problem and will probably need to be replaced.
Sep 15, 2011 | EnGenius EUB-9701EXT2 Pre-802.11n Wireless...
Tip
How to fix ?USB device not recognized? error in windows
Are you getting a “USB device not recognized” error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device”. 42b721d.png
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
on Jul 08, 2010 | Computers & Internet
Usb device installed but does not show up in my
First, try it in a different USB port on your computer.
Connect it to a different computer.
If it is still _not_ recognized, then it is "dead".
If it is recognized, then it's your computer that has the problem.
Jan 24, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
Computer won't recognize printer
Try each of the USB ports on your computer.
Assuming that you have a USB-cable between the computer and the printer, unplug the USB-cable from the computer, and connect some other USB device (iPod or memory-stick). Does Windows detect that other device? If not, then you need to install the correct software device-drivers for your USB ports.
Is the printer properly detected when connected to some other laptop/desktop computer?
Sep 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
The archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
Mar 20, 2009 | Archos Internet Media Tablet MP3 Player
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Usb problem
You shouldn't need the USB driver 2.0 from mercury because windows installs this with SP2. Suggest you un-install what you installed from mercury & update your version of windows (completley), through "Windows Update". Once windows is all updated & you have finished with a reboot. Plug your pen drive in a opened usb port. Open windows explorer. Scroll down & you should see an icon (left side of explorer), thats named like, Removable Disk. Give windows time to see the device. After a few minutes if your pen device does not show up try another usb port. One you know does work. If after a couple of minutes go by & you still don't see the device listed in explorer I would say the device is defective. Your Mp4 uses a cable to connect to the usb. Try connecting to another PC's usb port. It is possible the cable is dirty or bad.
Jan 13, 2008 | Mercury P4VM800M7 Motherboard
Dual Electronics CECT P168 Cellular Phone Logo
115 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
