Question about JVC Video Cameras
Jvc- gr-d740 camcorder's cassette is not ejecting message is showing that unit in safeguard mode please advise
  • 156 Answers
There should be an error code star with E-01 to E-06.Below is an example you have to make sure that which error code showing on your camera
Whenever some abnormal signal is input to the syscon CPU,
an error number (E01, as an example) is displayed on the
LCD monitor or (in the electronic view finder).
In every error status, such the message as shown below
E01 LOADING--------
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA
Posted on Sep 28, 2009
  • JAYA SANKAR
    JAYA SANKAR Sep 28, 2009
    E01 LOADING--------
The cassette holder wont come up aoutomatically
what you have to do is ejecting the tape, and as soon as it starts to eject , close the door immediately, then safeguard mode should be gone, and you will be able to eject normally.
Mar 04, 2008 | JVC GR-D290 Mini DV Digital Camcorder
My camcorder is on a safeguard mode, how do i take it out of the mode
Please go further down on the message, you must see a numeric code, like 03, or 02. In case you'll see 03, open the cassette door(let it open until cassette come out) about 5 sec or more(make sure you have enough batt. charge or use adapter). Once ejected do not use that cassette again. Using new cassette and same thing happen, have your camera checked by the expert. Error code other than 03, you need to consult the expert. Hope it helps
Mar 01, 2010 | JVC GR-D270 Mini DV Digital Camcorder
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Aug 26, 2008 | JVC GR-D250 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Video Cameras Logo
546 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
