System won't boot with this in. I tried 2 of them in 2 different sata ports, and also tried jumpering for 1.5 Gb/s. The disks worked in my Mac. Now I want to put them into my dual Opeteron (Tyan K8 motherboard) so I can use for Windows 7. Any suggestions? The boot lists the drive type and hangs.
No BIOS updates available. And you cannot get to the BIOS until after the SATA drive boots, so it is impossible to see if it is recognized.No BIOS updates available. And you cannot get to the BIOS until after the SATA drive boots, so it is impossible to see if it is recognized.
You can't post conmments that contain an email address.
The hard drive / optical drive have jumper settings, not the motherboard. PATA has jumper settings, but SATA do not require any. The diagram of the setting is drawn on the hard disk itself below the serial number etc. For SATA, look on the motherboard for the SATA ports. Each port will be named as like SATA 0, SATA 1 etc. If you want the hardd disk to boot first, plug it in SATA 0. and the next device in SATA 1. However, you can also set the first and other boot device from the BIOS itself, in case of SATA.
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
SATA drives do not have any jumpers.
If you were the one who mounted the EIDE drive into the external-case, be sure to set the jumper to "master" (not "slave", and not "cable-select").
Try connecting the external case to a different computer, to see if the unit works at all.
Remove the disk-drive from the case, and connect it as a "slave" disk-drive in some desktop computer, to see if it can be detected at all, when _not_ using the USB-to-Disk-Drive adapter.
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary". Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices. Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below; http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Not much info to go on but.. 1. Try swapping the connector between SATA port 1 & 2. 2. On boot enter BIOS, if it is recognized as a device in your BIOS then it is simply a formatting/windows issue. 3. Does it show up in windows Device Manager & is the driver installer/working properly? If not, uninstall driver and let it install again automatcally. 4. in control panel under Adminstrative tools open Computer Management, in left-side menu select Storage->Disk Management, it may show up as unallocated drive / disk space, quick format it with NTFS file system.
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using. Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost. Of course I am assuming that you are using a PC and not a MAC. -Aaron
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20. If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows: Connect the ATA IDE to MB primary master IDE port. Connect the ATA SATA drive to the MB's first SATA port. ATA Configuration Set as, [P-ATA+S-ATA] S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller. P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller. On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]". Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three. First boot device [Floppy] (If you have a floppy disk drive connected.) Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master. Third boot device [ATA IDE drive] If your boot drive is the SATA drive than set: third boot device to the SATA drive. (Hard disk drive with operating system loaded on it). Save your changes & exit the bios. Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number. Save & exit the bios. The system will auto restart. Windows should start.
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Hi abhinav13, please disconnect you're IDE. (do not remove it).
You're board only supports SATA 1.0 which is 1.5BG & not the SATA II at 3.0GB. Knowing that you may need to use the jumper to set the drive to 1.5GB. Once you are sure the drive is set correctly than hook it into the PC. If after disconnecting the IDE & SATA drive is shown in the bios. Set the jumper on you're IDE to function as a slave drive.
Enter the bios again. If you do not find the SATA drive listed than your onboard SATA controller is defective. You can not fix that.
So hate giving out bad news.
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
