Question about Whirlpool Refrigerators
Whirlpool gold side by side refrigerator is not cooling correctly. Inside temperature on setting of "6" was 41 degrees. On "5" it read 39 degrees. Noticed that it seemed warmer than usual yesterday and have been monitoring since. Situation is not getting better. Freon? Freezer does not seem to be affected.
    Problem Solver:
  • 17 Answers
Does this fridge have the controls on inside of the doors mounted to the ceiling., If the freezer is located on the bottom , then the freezer hepls cool the fridge via a channel in the back and a small door is controlled by the PC or Jazz board, When the fridge calls for coold air it opens the small door and turns on the fan in the freezer and blows air up the channel into the fridge, Check and make sure the fan works and the small door works Properly. There should be service instructions on the bottom of the fridge. Follow the direstions and it will help you find which component may not be working. In My case the PC board was bad. Which was located behind the control buttons.
Posted on Oct 07, 2009
    Sergeant:
  • 272 Answers
Greetings,
I'd be looking at a froze over evaporator.. The freezer usually will seem okay, and the refrigerator will be getting warmer. however, after awhile even the freezer will go out if its froze up.
The thing you need to do is determine if your freezer evaporator is frosted. If so, the air will not be able to draw thru the evaporator and get over to the fresh food section. So, defrost the coil if it is froze up and this will give you temp service.
Its difficult to troubleshoot this,but if you have a ohm meter, you need to check the resistence of your heater and defrost thermostat. if these are good..Its possible your adc is defective..9The timer)
Posted on Oct 03, 2009
I have a whirlpool ed22pq fridge that is shutting down. I have cleaned, checked the compressor relay, both fans seem to work ok, does not appear to freeze up. I saw on a blog, a guy said to gently hit beside the control panels, on the refer side. I did and it came on, worked for 2 days, shut down last night. I hit the panel and it is currently working. Any thoughts? Friend said he thought it was a thermostat sticking, but do not want to open things up until I have an idea. Would appreciate any help.
Posted on Aug 21, 2013
Temperature settings 1, 2, 3, 4, 5 means
refrigerator dial settings work from hot + 5 degrees (5) to real cold (1) 0 degrees and in the freezer section they work in the opposite direction (1) is cool - is minus 5 degrees and ( 5) is minus 25 degrees
those figures are example figures to show how the temperature in the units will be in relation to the dial numbers
Apr 27, 2015 | LG LSC26905TT Side by Side Refrigerator
I have a Whirlpool Gold side by side bottom Freezer gi7fvcxwqoo. The refrigerator side is not Cooling very will. The freezer seems to be ok! Does anyone know what's wrong?
Either the refrigerator is too cold to run properly in the location of your patio, defrost failure. or air damper is not opening and closing properly. First I would like you to enter the control panel into diagnostic mode=> GI7FVCXWA GI7FVCXWB GI7FVCXWQ Diagnostic Test I am going to be here to assist you in locating the problem but because your model has so many electronic features I am asking you to do the diagnostic test first to help pinpoint any problem your refrigerator may have that can be located while in diagnostics. You may get the complete repair manual by contacting me HERE
The temperature of the freezer should be colder and around 0 degrees F. What is happening here appears to be a defrost problem. 12729123 Defrost Heater
another source here=> 12729123 Defrost Heater
I am here so please let me know if you have questions Thanks Sea Breeze
Apr 22, 2013 | Whirlpool Refrigerators
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    How to set a temperture
    By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
    The following steps below is how to set the temperature of your refrigerator.
    The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
    Step 2
    Place your magnetic thermometer in the refrigerator.
    Step 3
    Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    Step 4
    After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    Step 5
    Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
    Hope this helpout and take care.
    Aug 12, 2010 | Refrigerators
    Whats the correct temperature the fridge should be set at? our milk goes off very quickly and nothing chills.
    A refrigerator should be set for a temperature of 37 to 39 degrees F. Refrigerator controls are not usually marked in degrees but have indications for "warmer-cooler". Set the control toward the cooler side and check the temperature. Place a reliable thermometer on a middle shelf to check the temperature. If the refrigerator is not able to maintain a temperature in the 37 to 39 range then the cooling system may need service.
    Oct 21, 2009 | Refrigerators
    My Whirlpool Gold Dishwasher isn't cleaning
    You need a new water valve. Call us for parts and supplies for your Whirlpool dishwasher. We will be sure to get the correct part out to you right away! We look forward to hearing back from you soon.
    Sep 09, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
    Frost in fridge
    you have a defrost problem call service
    Mar 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Our brand new whirlpool side by side refrigerator is not staying cool on the refrigerator side. On the recommended setting of 4, the temperature inside is 58 degrees. This happened to one we got two...
    You may want to look at your owner operator manual for the Whirlpool hot line for customer service. They would be able to walk you through a system check and recommend a solution to your problem.
    Jun 29, 2008 | Whirlpool Refrigerators
    Cooler wont cool below 48 degrees.
    Keep a thermometer handy. (adjust temperature control knob accordingly)
    Periodically monitor temperatures inside your cooler. (adjust as necessary)
    Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
    The temperature of the refrigerator compartment is
    controlled by adjusting/setting the thermostat control
    knob, located on the ceiling of the refrigerator
    cabinet.
    To start the refrigerator, and achieve maximum
    cooling quickly;
    • Turn the temperature control knob (using a coin
    or screwdriver) clockwise to the furthest
    (maximum) setting on the darker blue section of
    the graduated control dial.
    • Allow the refrigerator to run at this setting for 3~4
    hours.
    • When maximum cooling is achieved, turn back
    the temperature control knob setting to the 2:00
    o'clock position on the graduated blue control
    dial.
    • Correct cooling temperature is a key factor to
    consider in storing and dispensing draught beer.
    • Optimum temperature for serving draught beer is
    between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
    • To maintain temperatures ranging between
    34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
    thermostat knob be positioned at the "2:00
    o'clock" setting on the graduated blue control dial.
    • To turn off the refrigerator, (no cooling) rotate the
    control knob to the "0" position.
    Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
    Refrigerators Logo
    235 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
