Question about Quinny BUZZ 3 Capri Stroller
One wheel moves when brake is released
Today I was using my quinny and it worked perfectly. I put it into the car and when I went to use it again one of the wheels remains stuck when I release the break. Any ideas what I can do????
  • 20 Answers
Take both the wheels off give all parts a rubb down in wheel area then try again if it persists lubricate the inside of the wheels as the breaks are pin type and settle into a groove to stop pram migh be getting stuck x hope this helps x
Posted on Dec 30, 2009
TGA Breeze S4. Why doesn't it freewheel?
hi George, if you took the brake apart , you reassembled that incorrectly as there should be a slight gap when moving the lever into free-wheel to allow the motor to move freely...Normal you put a plate the wrong way during reassembly ...a common mistake...
Now with the free wheel working correctly both wheels will move in the same direction when the brake is released either by powering forward or backwards or using the freewheel lever has released...what you described is a normal action ...because they can move independently...that's by design.. so strip the brake again and make sure plates and springs if fitted are the right way round...
Regards
Mar 01, 2016 | Health & Beauty
Brakes Frozen
Hi Angie
Please contact Mothercare for assistance. Contact Mothercare
Jan 05, 2014 | Quinny Buzz Jogger
Mothercare my3 brake stuck
Hi Angie
We would recommend you contact Mothercare for assistance.
Ask Mothercare question
Jan 05, 2014 | Baby Gear
Quinny brake release pedal not working
Hi
There is a page attached for adjusting Quinny Buzz brakes. Try this and see whether it resolves the issue.
If it doesn't resolve the issue, the next step is inspection of the unit. If it's under 2 years old and you're in the UK, please contact your retailer with proof of purchase for them to arrange inspection under warranty terms and conditions.
If it's over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
If you're not in the UK please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab for your enquiry to be sent to the customer care team for your country. 3_23_2013_9_05_40_pm.jpg
Mar 17, 2013 | Quinny Buzz Three Wheel Stroller
Left e-brake on and drove 6 months ago wrecking the cable which leaves the e-pedal down. And now no e-brake. Today rotated the tires and put the truck back on the ground only to find that it will not...
Pull the ebrake pedal up with your foot while pulling the ebrake handle with your hand. The ebrake on the wheel that is locked just disconnect it from the wheel brake! cheap fix
Mar 24, 2011 | 1990 Dodge Ram
Hi, i have a 96 ford contour, it has been sitting in a driveway for a few months but running perfectly. just the other day we went to move it out of the driveway and the rear brakes appear to be stuck... i...
often the parking brake cable does not release after the car has been sitting, causing your problem.
I would jack up the rear end, put both sides on stands, and get underneath and see if there is any play in the cables. If the handle is released there should be some slack and you should be able to get some movement, with a set of vise grips, on the cable where it enters the back of the brake drums.
Oct 20, 2010 | Ford Contour Cars & Trucks
How do i lock the wheels in place on my Quinny Zapp?
Hi, they have an instruction manual for the Quinny Zapp over at the following link:
http://www.freebabymanuals.com/quinny/prams/Page-2
It explains how to do it.
Hope that helps.
Jun 03, 2010 | Quinny Zapp Umbrella Stroller
Jamed brake
try emergecy brake release if wont release you might have to drive it till it unlock or get somebody to unattache it
Apr 12, 2009 | 1997 Toyota Camry
My brake on my quinny buzz no longer works - help!
This happened to me on both brake pedals, nothing happened when I tried.to put them on, the pedals just did not move at all. I tried adjusting the brakes as per the dorel video on you tube, but still nothing. My husband found the solution though. He worked some oil into both pedal mechanisms and worked it through until both pedals moved again, once he had plied through a couple of times, both pedals and the brake now work fine, just turned out the pedals has seized over the years and just needed a good oiling. Worth giving this a try.
Mar 01, 2009 | Quinny BUZZ 3 Capri Stroller
Ford f250 four wheel drive electric selector problem. Will not shift out of four wheel low.
i have 2006 f250 4x4 will not engage unless i lock in hubs. once hubs locked in i can engage 4x4 by using electronic selector. why will it not engage when hubs are in auto and electronic selector is on 4high
Dec 21, 2008 | 2006 Ford F-250 Super Duty
Quinny BUZZ 3 Capri Stroller Logo
253 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
