Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Sep 25, 2009- I have a Canon Mp390I have a Canon Mp390 Printer/Fax/Copier which was working well. A neighbor called down and i sent a fax on her behalf. After which i copied some docum,ents to forward to my chemist whereby the printer displayed an alarm and suggested i press the OK button which i did and then if that did not solve my problem i was to remove the plug from the wall for 5 then 10 minutes. This did not solve my problem so i reloaded the whole thing which didn't help either. At all times the display in the top left corner of the screen shows #345 which i am unable to ascertain what that means. Are you able to help. Kind Regards, Clive Waldron I do not lnow what to add other than no matter what i do whether it be remove the plug for a time or hit the OK button or stop/reset nothing works..
4 Suggested Answers
Adi_Taticu
  • 71 Answers
SOURCE: Receive message 345 and alarm which prevents operation.
Other Canon models "may" be repaired with these instructions also, for example MP370, MP390, etc. Try with your own risk.
Symptoms:
-Grinding noise (very loud)
-Flashes error code ##345
Error code ##345 = "BJ cartridge head cleaning error" -reasons for this are:
-Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up. Make sure waste ink pump rotates freely, after cleaning. Clean the waste pump-hose too! Waste ink pump is located under head cleaning system.
Short solution:
1.Take apart and wash the ink clogged mechanical parts. Use hot water.
2. Reset waste ink counter
purge unit: HM1-0723-000
see more parts: http://www.e-parts.fr/pictures/uploaded/files/MP_360_370.pdf
I hope this is useful
Posted on Oct 04, 2009
emissionwiz
  • 76673 Answers
SOURCE: MX 420 Canon will low ink stop this printer from faxing? if so i think there is a override
Press and hold the stop button for about 10 seconds.
Posted on Jan 10, 2017
I need a free user manual download for a Canon MultiPass MP 390
You can get check it here:
http://soft-manufaktura.ru/manual/hp/mp390sm.pdf
Nov 15, 2011 | Canon MultiPASS MP390 All-In-One InkJet...
Multipass mp390 cannot fax
There are many things that can cause that, the error number is listed with the NG code. Could be the fax on the other end not responding, bad phone connection, improper setup like the setting for pulse and tone dialing. or using a digital phone line instead of analog.
Dec 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
How can i fax from a printer
hook your phone line up to it.  Hit the fax button, set your document in the feeder face down, and dial a working fax #, and then hit the send or enter button.  Let the fax do its thing and voila fax sent.
Oct 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have a Canon Mp390 Printer/Fax/Copier which was working well. A neighbor called down and i sent a fax on her behalf. After which i copied some docum,ents to forward to my chemist whereby the printer...
I don't have that particular model. Is there a Canon dealer in your area who you can call to find out what the code means? Otherwise you might want to contact Canon through their own website.
I can tell you one thing about the Canon MP450 though. If any of the cartridges are empty the alarm light will come on and it won't send the FAX.
Sep 25, 2009 | Computers & Internet
Can not recieve incoming faxs
You can download the manual from Canon.
My incomming fax doesn't work either.
Mar 18, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Mulitpass mp390
1) Push Fax button
2) Use number buttons to put in telephone number of where you want fax to go to.
3) Lay item to be scanned (faxed) face down on glass and press Start button (Black or Color)
4) Repeat step 3 for each item to be faxed.
5) When ready to send fax (done scanning) press Set button
Nov 26, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon multipass mp390
just put the number in and keep scanning the pages when you want t fax it the printer should say send fax and it will send it all. When you select fax option it should run you through how to do it if above doen't help.
Mp390 on startup cartride jammed clicking
I had the same prblem and ended up trashing mine.
Jun 04, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon multipass 390
alarm is flashing and flashing put in cartridge even though I've put in both black and color new cartridges and reset both still won't print
Mar 25, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
