Question about Epson Stylus CX4800 All-In-One InkJet Printer
Black ink covers the entire page. Does not print
Black ink covers the entire page when I print. Does not print images or text.
I cant seem to print text. i can only print graphics. i recently put in new ink cartridges, tried to print a page of only text and the pages were blank. tried to print another page with text and graphics,...
Have you tried printing text in different colour if that works the black jets are blocked- try running the cleaning cycle to clear (it may not use black ink in graphics)
Nov 15, 2010 | Brother DCP 130C All-In-One InkJet Printer
Printed page is just about entirely covered in black ink no matter what you print.
Replace your black cartridge, the waste hopper is overflowing onto the page.
Jul 27, 2010 | HP LaserJet 2300 Printer
The black text in my documents is not printing. I
Please check the black ink cartridge 1 The ink may have finished. Replace the cartridge with a new one 2 It is not seated properly in the print head. 3 Also check if the thin plastic film(so that ink does not dry up in packing) covering the ink pad in the cartridge has been removed
Jan 27, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Too much ink to few padges printed
The 1000-1500 mark is usually just a guess - it usually assumes no more than 15% coverage of the page.  If you are printing out very large pictures (full page images) or are printing lots of a single color (green landscape images), then the ink will run out a LOT sooner.
May 27, 2009 | Office Equipment & Supplies
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
