Question about NorStar T7316E Corded Phone
Voicemail message repeats itself and does not beep for message
The voicmail message repeates itslef and does not beep for clients to leave a message they have to wait a while until they can leave a message. How can I delete one of the messages?
    President:
  • NorStar Master
  • 860 Answers
Sounds like your main greeting and your general delivery mailbox message might be the same. Try altering the main greetings message to see if the messages differ from each other
Posted on Sep 26, 2009
  • george  peters
    george peters Sep 26, 2009
    sounds like your main greeting and your general delivery mailbox message might be the same. Try altering the main greetings message to see if the messages differ from each other
I installed this router on repeater mode, connection to existing router and signal is perfect but have no access to internet... in the access router the internet access is perfect. please let me know how I...
this is from Encore-usa.com
How to use ENHWI-N3 / ENHWI-N34D / ENHWI-2AN3 / ENHWI-2AN34D / ENHWI-3GN3 as a Repeater?
  • For Advance Users, you can download this document.
  • The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
    The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
    Checklist:
    • You should know the wireless security type of the existing wireless AP/router, is it a WPA, WPA2 or a WEP?
    • The wireless security key, or password or passphrase of the existing wireless router
    • Your existing wireless router's SSID
    • We recommend that the existing network you are about to add the Repeater on have a DHCP server running and able to lease IP address to all network clients. If you are not sure about this, please ask your ISP or the person who installed your network.
    Hardware Checklist:
    • Computer with wireless device turned off. This is only to set up the repeater, once finished the wireless can be turned on again.
    • The computer must have an available RJ-45 network interface card and web browser installed.
    • A working wireless router or Access Point with one available RJ45 port
    • RJ-45 UTP/TP Ethernet LAN Cable
    • The Encore Router is set to factory default. If your Encore Router is brand new and just pulled out of the box, no need to reset. If changes were made to any settings to the Encore Router before, make sure you "hardware reset" the Encore Router to the factory default settings. Check the User's Manual on how to "hardware reset" the router.
    PROCEDURES:
    1. Hooking up hardware connections:
    1. Both PC or Laptop and the Encore Router should be turned-on.
    2. Disable the wireless client from your PC or laptop computer (if not done so)
    3. Connect the Ethernet cable to the PC or laptop computer and the Encore Router. (This can be done while PC computer and router are turned on.)
    2. Switching mode from AP Mode to Repeater Mode
    1. Using your computer's web browser such as Internet Explorer or Safari Firefox, enter 192.168.0.1 to the address field then hit enter. You should see the Encore Router's User Interface screen still in the AP Router Mode
    2. On the upper right corner of the user interface menu, click on the drop down menu and select "Repeater Mode". Click the "OK" button to the warning box. Wait around 35 seconds until your screen comes back to Encore user interface screen, this time the screen is now in the Repeater Mode. If for some reason you were asked by the repeater to enter the username and password, enter the default username and password (admin/admin) and your Encore Router is now in Repeater Mode.
    NOTE:
    As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
    3. Connecting your Repeater to your existing network access point or router:
    1. As soon as the Encore Router switched to the Repeater Mode, you should be able to see the same Utility Screen with fewer selections on the left pane.
    2. From the Main Menu screen click on "Wireless" located on the left pane.
    3. Click on "Site Survey" button, a new Window dialogue box will pop up showing a list of Access Points reachable by your Repeater
    4. Check your existing network's access point SSID then click on the radio button that corresponds to your access point router then click "Connect" button.(If you can't find your existing AP router, click on "Refresh" repeatedly until your access point show up, or your location is too far from your existing AP router).
    5. Click on the "Encryption" drop down menu, select your existing access point wireless security, enter your existing router's wireless security key or passphrase then click "Apply". If you get a FAILED message, repeat this procedure again, a wireless hiccup might be interfering, otherwise you now have a working Repeater.
    6. Check your repeater connection by going to your internet browser and open a web page of your choice. If successful your new wireless repeater is working.
    7. Disconnect the Ethernet cable and setup your computer back to its original wireless settings. At this stage, the Repeater is now invisible to any wireless client computers. When connecting a new wireless client within the repeater's wireless range the process is the same as there is no Repeater device at all, the SSID of the wireless router will just be extended in range around where the Repeater is physically located.
    4. Connect your remote wireless client to your wireless router
    1. Using your wireless client utility program, look for your existing router's SSID and connects to it, if this is a new client you will be prompted with the wireless security key. Your repeater is invisible to all wireless clients. All it does is to repeat the wireless router signal as it is to extend its range. Once you have converted the Encore Router to Repeater and successfully connected to your existing router there will be no more configuration needed to the repeater. If you happen to see two identical SSID's of your existing router, this means your wireless client is within the same range of your existing router and the new wireless repeater, then your client don't need the repeater's service.
    NOTE:
    If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
    NOTE:
    When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
    5. To check the Repeaters user interface
    At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
    1. Disable wireless connection or turn off wireless in the client PC computer
    2. Connect Ethernet network cable to the RJ-45 port of the client PC computer
    3. Connect the other end of the Ethernet cable to one of the LAN ports of the repeater.
    4. From your computer, set the network card IP address to Static IP Address entering 192.168.0.102, Subnet Mask 255.255.255.0, leave the rest as blank.
    5. Open IE or Internet explorer or any other web browser software and run 192.168.0.1, you should be able to see the Encore Repeater user interface screen. (Changing any settings in the repeater may affect its performance)
    That should help :)
    Christopher
    May 15, 2012 | Encore Enhwi-2an3 Wireless-n Router
    WHEN I PRESS 1 TO LEAVE A MESSAGE IN MY VOICEMAIL BOX THE MESSAGE REPEATS
    The number to repeat a voicemail is 1, you must first go back to the main menu and click 1, make sure you are at the main menu first. Also, if not, I believe the button is 2 on some phones, try both.
    Mar 20, 2012 | Nortel T7316E 2-Line Corded Phone
    How do i check my voicmail when theres no messages on the machine?
    You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
    Sep 04, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
    I had a voicmail that I had saved on my phonen I went to listen to it, it was automatically deleted. That is a very imprtnt voicemail that I needed. Is there any way to get it back?
  • Start by tapping the "Phone" icon on your iPhone.
  • 2 Next, access your voice mail messages by tapping the "Voicemail" icon.
  • 3 Look at your list of current voice messages. If you have any messages that are eligible for recovery, you'll see an item at the very bottom called "Deleted Messages". Tap on this to access a list of your deleted messages.
  • 4 You should now see a list of deleted voice messages. If you see the message that you want to recover, tap on it and choose "Undelete".
  • 5 Your voice message will now be sent back to the main list of current voice mail messages.
  • 6 Repeat steps 1-5 for "each" message you wish to recover. This may take time!
  • Read more: How to easily recover accidentally deleted iPhone voice messages ' eHow.com http://www.ehow.com/how_4707121_accidentally-deleted-iphone-voice-messages.html#ixzz1A0684OUB
    Aug 04, 2010 | Apple iPhone 3G
    How do you set your voicmail on the lgneon
    To set up voicemail, push and hold the number 1 key until it dials into your voicemail box, then listen and follow the prompts to create a password and leave a standard or custom greeting. If this doesn't work, contact your carrier to reset the voicemail on your account. Hope this helps!
    Jun 20, 2010 | LG Neon GT365 Cell Phone
    How to enter radio code for siemens vdo c500
    It is showing SAFE because wrong codes have been entered.
    To restore, leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself (usually an hour or two.)
    Code Entry Instructions
    Switch the ignition key ON
    Press and hold AS button * and the ON button at the same time
    Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
    Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
    Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
    Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
    Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
    If the display now shows the correct Code number then
    Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
    May 22, 2010 | Car Audio & Video
    Triple beep
    May 16, 2010 | Uniden DECT 6.0 Cordless Telephone...
    Voicemail and Txt alert sounds
    then you will need to have the firmware reflash or take it to the store and hvae them explain why it is still doing that.....the phone firmware may need fixing.
    Sep 10, 2008 | Motorola Mobility RAZR V3
    Voicemail Icon
    I had the same problem at one point in time. However, I figured out that when someone calls and leaves a voicemail there is a message that appears saying "1 new voicemail". Try hitting the "listen" option and let it take you to voicemail that way instead of cancelling out of that option to see your missed call. That should make it go away. If not, then I have no idea.
    Aug 06, 2008 | LG CU400 Cellular Phone
    NorStar T7316E Corded Phone Logo
    359 people viewed this question
    Top NorStar Lands Phones Experts
    Oloyede Monsuru
    Jose Ma DM.
    Jose Ma DM.
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
