Question about Crosley CRFF16 15.9 Cu. Ft. Frost-Free Refrigerator with Recessed Coils in Stainless Steel
Vibration noise while running.
My refrigerator is really loud while it's running.  The noise comes from several places mainly in the back but also from underneath.  I thought I could try to tighten any screws I see in the outer housing but I have no clue about the sounds coning from underneath.  Any ideas?
    Sergeant:
    Champion:
  • 262 Answers
This sounds like the condenser coil under the unit it is the black thing that usually has a fan blowing across it but it can be between the compressor and the front panel under the ref. you can use card board to secure the condenser from rattling. good luck I chase these noises all day at work and they can be a pain to find and take a while and ALOT of patiences.
Posted on Dec 17, 2007
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
2003 Mitsubishi Outlander Grating Noise, Front Struts?
It very well could be the strut.
smaller chance could be the CV axle.
Also have the splash guards/heat shields checked to make sure they are all tight in place.
Mar 18, 2014 | 2003 Mitsubishi Outlander
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Very LOUD banging noise from front left wheel
the right outer tierodending needs replaced.
Apr 03, 2010 | 2001 Chevrolet Impala
Loud humming noise (vibration) from freezer section when running. Amana refrigerator (freezer on bottom) model BC21VW
Remove the back panel and see if the fan is turning. You will need it in the running cycle with the door switch closed. The noise your hearing is probally the fan assembly AP4008960. Make sure it is mounted tight and the back panel is not rubbing or loose. If the fan is making noise with the panel removed replace.
Mar 24, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Refrigerator Compressor has loud vibration
Clean the coils. what you are hearing is the valves as the pressure equqlizes. Also make sure that the fan by compressor is on while compressor is running.
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Top...Brand new, loud icemaker & door vibrating
you may think its comming from the door but check the back of the frige it could be your cooling fin radiater if we can say when you here the noise listen closly then touch the tubings or the radiater in the back you will find where its coming from it may be a loose scew causing vibration
Sep 26, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kitchenaid refrigerator stopped cooling
Yes, it will cost you at least $150.00 for a repair tech to walk to your house, but your case sounds like your motor had problem, When the motor running loudly for several weeks, because it lack Freon R-22, that why made a loudty noise, some place is leaking very slowly, your compressor need freon. I think it is going to cost you at least several hundred to repair it, but if you can find a used working Reg.probably you can save some money.
Please ask your friend who might give you some their opions.
Jul 10, 2008 | KitchenAid KSRS25IL Side by Side...
Crosley CRFF16 15.9 Cu. Ft. Frost-Free Refrigerator with Recessed Coils in Stainless Steel Logo
674 people viewed this question
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
fta777
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
