Question about Frigidaire FRT22TSE
My Frigidaire FRT22TSE's defroster isn't working. I took the back out of the freezer and defrosted the coils and it works now. But, how do I correct the problem so this won't happen again?
That answer is not what the DIY-person wants to hear. They want to hear that the timer is located in top of fridge section and is part# 215846602 usually <$20 @your local appliance store. I know cause I did the troubleshooting and repair of mine! In my case it was always on. I'd still bet that his has same problem but good to also check thermostat and heater with ohm meter for continuity. Don't know about this site but searspartsdirect.com has parts blowups & all parts numbers.
Posted on Nov 25, 2009
  • 146 Answers
Is your unit under warranty ? Call for service and have them replace the defrost timer control board and check the other defrost components - you also could try to locate the board online although I do not recommend it unless you are comfortable working with wires and circuitboards. It's best to have a service person also check the other components, the heater, continuity, defrost timer, control board, etc as well.
Posted on Sep 25, 2009
My freezer is froze
The defrost element and/or timer.
Sep 01, 2017 | Frigidaire Freezers
Fghs2665kf2 side by side freezer works fine fridge side warming up
The leading cause of the refrirgerator not working while the freezer is is good,is a defrost problem,do you see a bunch of frost built up on the back wall inside of the freezer?? If yes ya see frost build up of frost in the freezer it will be a problem with the automatic defrost system. This tip i wrote covers what to check when it isn't defrosting by itself.
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 08, 2011 | Frigidaire Side By Side Refrigerator 26...
Freezer coil, inside freezer compartment continues to freeze to a solid block of ice. Apparently the auto defrost isn't working. I can manually shut it down, thaw it and restart. It works fine for...
Your defrost circuit is made up of a defrost heater, defrost thermostat and a defrost timer (generally, but will depend on make and model). They are relatively straight forward to troubleshoot and replace, and not that expensive.
Suggest you go to www.searspartdirect.com and plug in the model number of your frigerator and look up the parts you need to get an idea of how much they are. NOTE: Sears isn't the cheapest place to buy the parts, but they use the real part number for further research.
Sep 10, 2011 | Frigidaire Refrigerators
Freezer coil inside freezer box loads up rhyme ice preventing air flow. If I defrost the freezer it will work fine for a few weeks. I suspect there is a defrost timer, or humidity control that isn't...
There are three parts to all defrost systems.
1. Defrost Heater2. Defrost Timer3. Defrost Thermostat
Without a model number I could not look up a diagram or part numbers. I very seldom see a bad heating element. Most common is a bad defrost timer, second most common is the defrost thermostat.
Aug 02, 2011 | Sub-Zero Freezers
My Fridge started getting war and the freezer part was real cool i unplugged it for a day plugged it back up and it started working 2 days later it stopped again this time i took panel off the back and...
  • Well I can say one of the components responsible for defrost has failed -defrost timer, defrost heater or the defrost thermostat.
  • Unplug the refrigerator and pull the back wall off of the freezer.
  • Now unplug the defrost and the thermostat.
  • Get your Ohm meter out and test for continuity across the heater and the thermostat.
  • No continuity on the thermostat means that needs replaced and the same for the heater.
  • If both of them parts test out OK then you need to replace the Defrost Timer.
  • One of them is bad guaranteed. You want to make sure that there is some fresh ice build up too after cleaning it all off. This insures that which ever component that might be bad is verified messing up again per the ice. Then do the testing.
  • Thank you for using FixYa.
Regards, Tony
Jun 18, 2011 | Frigidaire Side by Side Refrigerator 23...
Coils frozeup and iced on top shelf of freezer---did a defrost--when shut the door don't hear the shhhh sound-nothing blocking it and seal is good--light is on but won't freeze any food--threw out alot! ...
Defrost the unit totally so you can see no more ice, may take a day or more with door open, once done, restart the unit, check you can hear the fan running in the freezer, if not, replace fan unit, if you can hear it, the defrost timmer may have failed or the defrost element has gone. If the unit appears to work correctly, dont be fooled, the problem will return, if the unit does not work as it should, regas is required. Hope that helps.
Dont forget to vote for the solution, thankyou
Mar 04, 2011 | Frigidaire 13.7 cu. ft. / 388 liter...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Refrigerators Logo
279 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
