Wii remote dead after a few seconds.. It is brand new, i put in the batteries, synched it up with the Wii, which works. Then it looks like the battery is empty and next it no longer resonses. Taking the batteries out and reinserting them again repeats the game. not even turning it on, but just pressing the 2 button several times and after blnking a few timeis it is dead again. Tried it with different new batteries.
Ok, there is a synch button in the back of the wii remote close to the battery. On the Wii itself there is a little drawer type area by where you put the game disc. There is a synch button there. You want to push both buttons, the one on the wii first and then the remote, they should synch from there rather quickly.
Hello there, what you want to do is open the back of the wii controller where you put the battery. Then you want to go to your wii and open a little slot drawer type thing next to the DVD slot. There will be a synch button on both the controllers and the wii, push the button. Note that you will have to synch each and every controller to each and every wii. Meaning if you go to your friends house and they have a wii you will need to repeat the process at their house and also again when you return to your house, but it only takes a few seconds for them to recognize eachother. Once you are synched to your machine if you dont take it to a different Wii you wont have to synch every time you want to play just the initial time. Happy Gaming
you probably have to resynch them. turn off the power button on console, then unplug from wall for 5 seconds. plug back in and turn on console. when the health and safety displays on the screen open the front of the console and press and hold the red synch button for at least 15 seconds. this clears all previous synchs. open the back of the wii remote and press and release the red button by the batteries. then press and release the synch button on the console. this should re synch the remote. repeat for any other remotes.
Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
The exact procedure is:
• Even if the battery level is strong, try the following:
Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
Try these steps!
Turn the Wii console power OFF by pressing the POWER Button on the
front of the console. Unplug the power cord from the wall outlet for a
few seconds. After a few seconds have elapsed, plug the cord back into
the wall outlet.
2 Turn the power of the Wii console ON. When
you see the Health and Safety screen, open the small flap on the front
of the Wii console to find a red button labeled "SYNC." Press and hold
the SYNC Button down for 15 seconds. This will clear all the syncs on
the Wii, allowing you to get a clean start to begin the process
described below.
3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
a
With the first Wii Remote you wish to sync, remove the battery cover on
the back of the Wii Remote to find a small red button just below the
batteries.
b Press and release the small red button just below
the batteries on the Wii Remote; the blue lights on the front of the
Wii Remote will blink.
c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
d
When the Player LED blinking stops and stays lit, the syncing is
complete. The LED that is illuminated indicates the player number (1
through 4).
4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote.
Press the Power button on the Wii console to turn it on.
Open the SD Card Slot cover on the front of the Wii console.
Remove the battery cover on the back of the Wii Remote you
wish to sync up.
Press and release the SYNC button on the inside of the SD Card compartment
on the console. Press and release the SYNC button just below the batteries
on the Wii Remote.
When the Player LED blinking stops, the syncing is complete. The LED that
is illuminated indicates the player number (1 through 4).
This procedure must be followed for each additional Wii Remote added
to your system.
The batteries might be dead or if they are not take the batterry case off and flip open the sd card place and hit sync on the remote then hit it on the wii
Well, pressing 1 and 2 doesn't work if your Wii remote came desynched. Press the Red Synch buttons on both the Wii console (located under the SD card flap) and the one on the back of the Wii remote, and hold one then the other for about 5 seconds. Should help.
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
Turnthe power of the Wii console ON. When you see the Health and Safetyscreen, open the small flap on the front of the Wii console to find ared button labeled "SYNC." Press and hold the SYNC Button down for 15seconds. This will clear all the syncs on the Wii, allowing you to geta clean start to begin the process described below.
Withthe first Wii Remote you wish to sync, remove the battery cover on theback of the Wii Remote to find a small red button just below thebatteries.
Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
