Question about Garden
I have a Toro LX 420 rider. When I turn the key I get a click which comes from under the seat where the battery and solenoid are. I have replaced the battery and solenoid to no avail. I guess the only part to replace is the starter. Any ideas.
  • hawkfins Sep 25, 2009
    All grounds are good. Anymore ideas.
  • 62 Answers
Make sure you have a good ground on the battery and the solenoid
Posted on Sep 25, 2009
Toro lx 420 wont start, sounds like starter wont engage jst a clicking sound. I put a new battery and solenoid in and still the same
Double check the cables and wiring as there may be a loose connection or a corroded cable causing voltage drop .
Jun 06, 2018 | Cars & Trucks
I asked a question about a toro riding mower but it was placed in the cars and trucks catagory
Depends if it is the starter solenoid that is clicking or the fuel solenoid. If it the starter and clicks try jumping the two large posts with a screwdriver that you don't mind damaging. If the starter now turns then it is the solenoid if not then it is starter. If the starter doesn't click then it can be a safety or ignition switch problem.
May 09, 2015 | Toro Garden
Toro timecutter won't turn over with key
Sounds like the solenoid is bad. Most solenoids connect positive + from the battery. One side will read 12 volts (with the black wire of a test meter or test light. (The side connected to the battery). Energize the solenoid (loud click) And with the key held, check the other side for voltage. No voltage, bad solenoid. Be careful when you buy a replacement. Many look the same but do different things.
Apr 09, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
starter motor i would suspect. try hitting it with a hammer to jar it into life. im sure its the starter motor.you could try running a positive from the battery to the positive on the starter motor to see if it turns if it does not replace srtmotor
Mar 08, 2014 | Vertex Ride On Mower
Toro Lawn Tractor Won't Start - Wheel Horse 13-38 XL 71185
well if it turns over with solinoind jumped out and not with the key id say yes your on the right track as it's something in the safe to start circuit could those wires you found posibly be near the seat maybe if so I'll bet they fit in a seat switch that may have got unhooked for something
Nov 12, 2013 | Toro Garden
Toro lx 500 riding lawn mower
check the connections from the battery to starter-check the fuses -and relays than start with the safety switches --seat-clutch-and cutter deck the safety switches are a kill switch
May 24, 2013 | Garden
I have 1995 toro ridding mower.i got it not working an the battery was not charging so i got a new battery an ones i hooked it up every thing work bu did not start an it just makes a clicking noise when i...
Test the battery with a volt/ohmn meter to ensure it reads at least 12-14 volts. Check all the safety switches located underneath the seat & the mower deck engage handle is disengaged. Check all battery wire connections are soldi, not corroded. Check wiring on starter solenoid from battery & to key switch.
Oct 24, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Toro LX 420. Bought in 2006. Put a new battery in and I get a click sound under the seat where the battery and solenoid are when I turn the key. Is it the solenoid or the starter?
Most likely it is the solenoid especially if the battery is new but the only sure way to tell is to test the battery with a volt meter for 12 volts or more or use a HEAVY jumper wire and cross the two large posts on the solenoid. If it cranks when you cross them, replace the solenoid. don't hold the wire on too long, it will get hot and melt the insulation
Sep 24, 2009 | Garden
Garden Logo
540 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
