Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Coolant leak the tube that sends the coolant to the refrigerator has a leak and was never found so it had to be refilled once a month.
    President:
  • 1,653 Answers
The leak is easy to detect with a UV light amd using coolant with a coloured additive..
Posted on Sep 25, 2009
Why did fridge stop working, then freezer 4 days later?
how it works. 6 month ago another technician came to this service call and found out that system is low on freon. So he charge it up with freon and add leak dye into the system. Leak was really slow, so he could not find at first. Here Im 6 month later, found leak dye with special light (dye leak set (tools) cost about 180$), did not need to order any parts, but replaced copper tube. Customer paid around 600$ for repair total for this repair. Hope That Helps!
Aug 16, 2015 | GE GDS18LBR Bottom Freezer Refrigerator
Antifreeze is leaking from the radiator? hit something, the honeycomb grill at the bottom pushed a small tube into what looks like the bottom of the radiator. Coolant is leaking. The tube looks like p
Get the coolant pressure tested, its definitely leaking coolant. You will need to get the coolant running line.
Pressure test will help you to know from where exactly coolant/refrigerant is getting leaked.
For complete step by step troubleshooting i suggest you to go through the help link mentioned below :----
Click the link below: -----
COOLANT LEAK ISSUES, COOLANT LEAK PROBLEMS, COOLANT SENSOR, LOW COOLANT,
http://alltypesofpartsreplacing.blogspot.com/2012/12/coolant-leak-issues-coolant-leak.html
These will help.
Thanks.
Dec 25, 2012 | 2008 Land Rover LR2
So my mini fridge seems to have stopped working it does run i can hear ir and the compressor is gitting fairly hot i have unplugged it over night and replugged it back in this morning and still seems to...
I apologize for being 1 month late in answering your question. I just answered a different post and your question appeared after answering the other post. Having said that here goes.
If the compressor is running reach down and touch the tubing that goes into the compressor. One of them should be very hot and the other one should be much cooler about 2 inches from the compressor. If neither one of the tubes is hot the coolant system it out of coolant probably due to a system leak. (i.e someone poked the coils defrosting the unit or.. there was soldering joint that had a slow leak and allowed the coolant to escape. Make sure to listen for the compressor running continuously vs running every 4 - 6 minutes (thermal overload cycling) If the drier is clogged where the capillary (small tube) connects to it there will be one hot tube at the compressor but no coolant flow.
Thanks for choosing FixYa,
Kelly
Feb 28, 2011 | Magic Chef MCBR360S Stainless Steel...
I have to keep refilling radaitor tank every two days
sounds like you have a coolant leak or your heads havent been done right or there maybe a crack in the head which has not been found.
Jul 06, 2010 | 2001 Chevrolet Malibu
I can't keep coolant in the bike once it warms up.
The cause is most likely a faulty radiator cap. Replace it if you can. It is not sealing properly, and allowing coolant to escape out the overflow tube. You can try cleaning the cap under running hot water, pressing down on the spring at the same time, to dislodge any dirt or grit.
Jun 25, 2010 | 2001 Honda VT 1100 C2 Shadow Sabre
Oil from lences leaked out and got on al the chips and wires what do i do
This is projection tv coolant. You need to clean all region on board where the liquid leaked and remove the tube who leak and flush the coolant. after good cleaning of tube and lens, reassable them and refill with new coolant.
Apr 22, 2010 | Sony KP-53HS30 53" Rear Projection...
VW Gold TDi 2005 and once a week I need to refill coolant
it looks like there is a leakage on the one of the tubes. I suggest that you take it to a mechanic
Nov 11, 2009 | 2000 Volkswagen Golf
Bot the fridge & freezer have quit chilling..
sounds like something pocked a hole in the refrigerant line ether inside or out side leak needs to be found and repaired with epoxy and coolant refilled
Oct 28, 2009 | Samsung Refrigerators
Motor running but does not get cold
There is a leak in the coolant cycle system or the seals are shot. Replacing the compressor and coolant will fix the problem if there are not micro leaks in the heat exchanger (tubes with grating) but it may be better to just get a new frige, depending on the model. Expensive ones are worth it, cheapies are not. You make the call when the cost of your parts and refilling are discovered. Remember all it takes is a leak one molecule wide, and the new refrigerants are now smaller, they leak through most rubber tubes but won't through metal.
Sep 11, 2009 | Refrigerators
Leak water on floor once a month
This likely a defrost cycle issue. Your drain tube is likely clogged. Get under there and clean it, clean your condenser while you're at it. Cut down door openings, open liquid in the fridge.
Jan 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
194 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
