Question about Dryers
Model: maytag LDE9606ACE reinstall belt
Installed new fan blade, and accidentally knocked belt off drive in back.
I need to know how to install the belt correctly?
Please advise. Thank you.
Mike
  • 5,911 Answers
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram E for a Maytag dryer. If you have questions, please let me know. I hope this helps you.
Posted on Sep 25, 2009
    President:
  • 1,922 Answers
Around the drum and motor pulley then push on idler pulley until you can get it around this pulley then release tension on the pulley and manually turn drum to make sure belt self aligns itself on the drum and you got it.
Posted on Sep 26, 2009
Why wont blades stay engaged ?
Check the drive pin in the tractor belt drive pulley. If the pin is broken it will have enough pull to turn the blades slow but will slip when the gas is applied. To repair you will need to remove the drive belt and take the pulley off the drive shaft and get a new pin and reinstal.
Jul 24, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
Why won't the blades engage on my Ariens 911403
Chances are the deck drive belt has been knocked off one of the pulleys or the drive clutch won't engage properly. With the spark plug wire removed, rotate the blades by hand and make sure they both move together. This verifies the blade linking belt is OK. Now engage the blade operating control and feel for resistance as you rotate the blades. If you feel no change in resistance, remove the belt cover and reinstall the drive belt over the pulleys and tensioner/clutch mechanism.
May 31, 2014 | Ariens 34 In. Zoom Series Riding Mower
Buick lesabre knocking
I am hoping you reinstalled the battery clamp and the battery is not dislodged and hitting against the fan. Please check to make sure nothing is obstructing the fan blades.
Oct 28, 2013 | Cars & Trucks
I engage the mower blades, put the tractor in drive and the blades stop
sounds like the safety switch is out of adjustment
Apr 06, 2012 | Garden
Maytag Dryer Model LDE9606ACE SN 10679440QU Quit and does nothing. What are the odds its a simple fix and what could it be. There is power 240V to the dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Maytag Dryers
Maytag dryer model number lde7334ace wont spin a full load of clothes we put a new belt on and fan blade now it wont spin a full load
recheck the belt, Tim:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 06, 2011 | Dryers
The blades wil not turn, I installed a new blade belt drive but must have installed it incorrectly as it broke immediately. Need instructions to install blade belt drive, please. Can you give me the...
Hello. Often when the belt brakes it is because one of the pulleys has frozen up. The best way to work on the mowing deck is to remove it from the tractor so you can see what you are doing, check each pulley, thoroughly clean and grease it. Definitely replace any pulley that is either frozen up or wobbly. Then get a belt especially made for your brand of mower. I would have given you a link to a manual but you did not tell me the brand and model. Get back on here with that info and I will be watching for you. FOUR thumbs up will be truly appreciated. Thanks. Joe
Sep 30, 2010 | Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Fan above drive belt pulley is hitting metal brace
If the fan blades aren't torn, you could try bending them back in place. I have had sucess doing that before. The plastic naturally wants to go back to where it was, with a little help. If that doesn't work, you can replace the fan, or have it replaced.
May 27, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Sep 22, 2008 | Freezers
Dryers Logo
609 people viewed this question
Top Dryers Experts
