Question about Pool & Spa
Heeeelp! How to hook up hoses on Sundance spa
I have a mid-90's 5-8 person sundance camino (?) spa shell. In facing the front of the shell, there is 1 hose on the left and two on the right. I will use our gas heater to go into the pump, but I don't know which of the three hoses are intake vs outake. I am presuming that a hose from the pump goes to the hot tub and ''T's'' to two of the three hoses on the hot tub. But, which part of the pump pushes water in and which part draws the water out? What goes where? Heeeeelp!!!
  • 990 Answers
There is a skimmer in the side of your tub( the part that skimms water off the top ) and what is called a main drain or a better tearm is deep suction that pulls water from the bottom of the tub and helps collect heavy dirt from in the tub these two lines ( three if there is more than one main drain) These will all come together and then hook to the front of the pump. If your filter is under the skimmer basket the top of the pump will go to the heater and then back to the spa. If your filter in not under the skimmre basket then it will come after the pump then on to the heater. So in answer to your second question, the front of the pump draws the water in and the top pushes the water out. But make sure that your heater is last in line so it only deals with clean water and it will not run on the suction side of the pump as it need water pressure in it to start and contious flow to keep it from over heating. Hope this helps.
Posted on Oct 03, 2009
No power to tub
open power control box check to see if voltage coming in. also check fuses. check voltage before transformer and after see if voltage is correct if you put in new fuses disconnect the heater element and the recirculation pump plug one in at a time to see if it blows fuses
Mar 22, 2014 | Sundance & Jacuzzi Hot Tubs Complete...
Sundance spa
may be getting water in the blower and the safety bypass is turning it on to blow the backed up water out of those lines..the tub may be too full..
Nov 14, 2013 | Pool & Spa
I have a 1991 plymoth sundance putting a after market radio in it i put the speakers in hook them up turn the volume all the way up and the music sounds real low what is the problem please
Sounds to me like the speaker wires may be reversed but then again I'm not perfect, just don't tell my wife that. Anyhow here is the wiring info for your vehicle just to double check. I hope this helps you and good luck.
1987-93 Plymouth Sundance Stereo Wiring Constant 12V+ Pink Switched 12V+ Red/White Ground Ground/Back Strap Illumination n/a Dimmer Orange/White Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 5" x 7" Side Shelves Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
Mar 28, 2011 | 1991 Plymouth Sundance
Looking for picture wiring diagram for audio to hook up a radio in a 1989 plymouth sundance
1989 Plymouth Sundance Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Ground Wire: Back Strap
Car Radio Dimmer Wire: Orange/White
Front Speakers Size: 5 1/4?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Green/Yellow
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Purple/Yellow
Rear Speakers Size: 5? x 7?
Rear Speakers Location: Side Shelves
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Brown/Yellow
Right Rear Speaker Wire (+): Blue/Red
Right Rear Speaker Wire (-): Blue/White
Nov 24, 2010 | 1989 Plymouth Sundance
WATER PUMP LEAKING
front of the engine see picture below.
Mar 09, 2010 | 1992 Plymouth Sundance
Where is te starter on a 1991 plymouth sundance what is it hooked
The starter is located on the bottom of the engine, where the engine and transmission meet. It is on the side of the engine closest to the front of the car. The easiest way to find it is to follow the positive battery cable, as it goes directly from the battery to the starter solenoid.
Jan 22, 2010 | 1991 Plymouth Sundance
Where is the staretr located on an 1991 plymouth
On the side of the engine block above the oil pan faceing the transmission.
Jan 21, 2010 | 1987 Plymouth Sundance
93 Sundance stutters and jerks on acceleration
It hooks up to the diagnostic port by the battery. But it sounds like you need plug wires.
Jun 11, 2009 | 1993 Plymouth Sundance
Pool & Spa Logo
290 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
