Question about Amana NED5500TQ Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
I have a Amana Electric Dryer NED5500TQ. When I got it, the Auto Dry System did not work...The Dryer would not shut off until I shut it off. Now, when I run the dryer it kicks off my Main Breaker on the incoming electric pole. What could be causing this?
    President:
  • 1,015 Answers
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Posted on Sep 25, 2009
I have a Amana Dryer NED7200TW. At the end of any drying cycle the dryer shuts off and then turns on again continuously untill i stop it. It also shows a C and a backward C in the display. Any thoughts?
You might need a new display board (electronic timer ). Seems like the timer will not send the message for the dryer to stop when the cloths are dry
Jul 25, 2012 | Amana NED7200TW Electric Dryer
My electric dryer will not start; model # NED5500TQ. I can hear the timer is working.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2011 | Amana NED5500TQ Electric Dryer
T5 and dryer not starting. not sure what model it is.
heatman101
Jul 21, 2011 | Amana NED5500TQ Electric Dryer
Dryer cord and power box fused replaced both no heat replaced
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 17, 2010 | Amana NED5500TQ Electric Dryer
Dryer won't start - was amking loud noise - loose change had gotten inside and after cleaning it all out it will not start
heatman101
Jun 15, 2010 | Amana NED5500TQ Electric Dryer
Dryer is not heating up
This is a simple dryer design. The limits and heater are all mounted on the heater assembly. 9ce9b7a.jpgGet the front off and take a look see. AMANA DRYER
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 04, 2010 | Amana NED5500TQ Electric Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
Amana NED5500TQ Electric Dryer Logo
158 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
