Question about HP PSC 2210 All-In-One InkJet Printer
My scanner is not working anymore
My computer crashed. I installed all original cd's everything new and now my scanning option is not working anymore. My printing option works fine.
I keep rebooting my system but that does not seem to help. What can you recommend that I do.
Thanks
Dinoza
  • 112 Answers
SOURCE: HP All-in-one will not scan
I think I have the solution for you (after facing similar problem). Try installing the drivers and then go to my computer right click on the HP and select "Scan using wizard". My HP is able to scan using this method although I still can't scan using the button on the printer so if you don't mind clicking the mouse instead of the printer's button you should be fine. Let me know if it worked. Cheers, D.
Posted on Jul 14, 2007
Atomik81
  • 46 Answers
SOURCE: HP OfficeJet 555 Printer (hardware) failed to install
Greetings,
Here is the link to the Hp driver page for your printer - Download the drivers and then reinstall them - This should resolve ther issue.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=57742
Posted on Dec 29, 2008
SOURCE: Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Posted on Sep 21, 2009
  • 4 Answers
SOURCE: When I try to scan, I get error message on printer
I think you have installed the HP full feature software in the computer.
You can check it, you need to click on Start button -> All Programs -> HP -> HP Director
please check if you are able to scan from HP Director (if yes then change the below settings so that you would be able to scan from the button on the unit)
open the HP Director -> click on "settings" -> scan settings -> scan to setup and you need to populate all the options which you see in the left panel. when you will populate all the options to right panel. Then click UPdate device or OK button. and then try to scan again from the button on the unit. It will work. If it does not then check for the DIM (Digital imaging monitor) icon in the system tray, it would have a green checkmark over it. if you do not see it then you have to start it from the below steps
please click on Start button -> My Computer -> C: Drive -> Program files -> HP -> Digital Imaging -> Bin -> hpqtra08.exe when you will double click on the file, you will see DIM icon in the system tray and you will be able to scan from the button on the unit.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01798218&cc=us&lc=en&dlc=en
you can also click on the above link to understand it better.
I hope it will definitely help you out.
Posted on Dec 11, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: My scanner won't scan - No Scan Options is
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00503569&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=439491
This page from HP will walk you thru the troubleshooting of a scaning problem.If you find that nothing on this page helps scroll to the bottom and click-Contact HP,for live help.
Posted on Mar 08, 2010
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner sees the Mac computer. Scan to computer starts with an "accept" command from the computer. Scan starts but then an "unexpected error" message appear on the computer and "there is no computer...
this happens to be drivers programs systems crash.
due to a virus infection,unexpected deletion or unknown settings changing for scanner.
the best way to resolve this is to go on control panel,add/remove programs and then search for the specific program for your device and unistall.this will delete the program from your computer then you will have to insert the drivers cd you purchased along with your printer and start a fresh installation.make sure that you have the cd first before uninstalling.
the other method is that you can insert the cd in the drive and start installing.thye registry will notify you that you are installing an already installed program.it might prompt you to repair or recovey depending on the model you have,select the option or you can overwritte the already excisting program which is the most appropriate.
Mar 22, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp c6380 scanner issues
Contact HP for Care at 1-800-585-2494.
Jan 19, 2010 | HP Photosmart C6380 All-In-One InkJet...
I can't manage to scan directly from the scanner
Hello
Have you installed full software from the CD that came with the printer?
if not do that first, do you mean that you cant push printer button and automatic scan to computer?
Jul 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
Hp psc 1215 wont scan with vista
Introduction Some products do not have full scan functionality in Windows Vista. This is because full-featured Vista drivers are not available for all products, especially older products. However, the Windows Vista operating system installed on your computer includes a basic print driver. This driver allows you to scan an original and save it as an image using workaround methods. You cannot use the advanced scanning features that you might have used with your product before you installed Microsoft Windows Vista. Scanning an original and saving it as an image Follow these steps to scan an original document, and then save it as an image. Step one: Load the original Follow these instructions to load the original in the product.
  1. Raise the top cover of the product.
  2. Place your original print-side down on the glass.
    NOTE: The engraved diagram next to the scanner glass shows exactly where to place the document (usually on the right-front corner or the left-front corner).
  3. Close the scanner lid.
Step two: Workarounds for scanning an original and saving it to the computer Select one of the following three workaround methods to scan an original and save it as an image. Method one: Scan with Windows Photo Gallery
  1. Click the Windows (c01319360.gif ) icon.
  2. Click Programs .
  3. Click Windows Photo Gallery . The program opens in a new window.
  4. Click File , and then click Import from Camera or Scanner .
  5. Click Import .
  6. Click Scan .
Method two: Scan with Windows Fax and Scanning
NOTE: This feature and the following instructions work only with Vista Ultimate, Vista Business, and Vista Enterprise versions of Windows.
  2. Click Programs .
  3. Click Windows Fax and Scan . The program opens in a new window.
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scan using Paint
  2. Click Programs .
  3. Click Accessories .
  4. Click Paint . The program opens in a new window.
  5. On the Paint toolbar, click File , and then click From Scanner or Camera .
  6. Click Scan .
Nov 30, 2008 | HP PSC 1215 All-In-One InkJet Printer
Help installing CanoScan 4400F
Here's the link for the drivers, just select your Operating System and language and you should be good to go. It also includes the software that you need.
Canon CanoScan 4400F Software Driver
Sep 18, 2008 | Canon CanoScan 4400F Flatbed Scanner
Trouble with an older scanner
I'm assuming this scanner interface is a SCSI connection. First thing you may want to look at is the SCSI ID number switch at the very back end of the scanner. Before changing the SCSI ID switch make sure your scanner is powered down. Repeat steps above when trying different SCSI ID numbers to see which one works with your computer. If you have other SCSI devices connected make sure they are not sharing the same SCSI ID # which will cause a conflict.
Jun 06, 2007 | Agfa DuoScan Flatbed Scanner
HP PSC 2210 All-In-One InkJet Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
