Lexmark E232 Laser Printer
Problem for Lexmark E232 Laser Printer
Paper jams constantly, without fail.
By aisling_com on Sep 25, 2009
Every page that goes through jams. It's being picked up alright but then just stops. Tray is clear, paper's straight etc, cleaned the rollers/wheels but no improvement.
Best Solution
posted on Oct 04, 2009
Helpful)
bambarm
Rank: Master
Rating: 95%, 13 votes
Hello, this problem may be able to be fixed. You have started out correctly by looking inside for something out of place and cleaning the rubber rollers that "grip" the paper. Next thing would be to get a higher quality of paper (heavier weight) and see if that fixes the problem. Often times a slightly heavier stock paper will work. Some of the cheapest papers are more slipery and thin. This may not be the solution you are looking for, becuase you have to use more expensive paper, but I have found that on an older inkjet printer it will allow you to print. If this does solve your problem, then you know that its a paper grip problem and you can go in and take some course sandpaper to your rubber wheels to make them grab the paper better. If this doesn't work get a flashlight and look into the paper feed when it is trying to grab the paper to make sure the intake roller is turning correctly and try to manually feed it through there by pushing the top sheet through if possible. It has to be one thing or another and you just have to go through the process of elimination to see what is going wrong with the mechanical process of grabbing the paper and getting it to go through. Most printers have a manual load area where you can feed paper through. If you have that, you can verify that the paper feed channel is unblocked. Often a tiny piece of paper is lodged somewhere that stops a new sheet from making its way through.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Lexmark E232 Laser Printer
Questions and Unsolved Problems for Lexmark E232 Laser Printer
Do you recommend Lexmark E232 Laser Printer?
Answer
Answer
I put in a brand new toner, but print quality is still bad. what should I do?Is there something else... (More)
Answer
I recently moved to a MAC and downloaded the drivers for my E232. I am unable to select for... (More)
Answer
The bottom light, looks like an exclamation point, stays on and won't print unless I push the apaper... (More)
Answer
test page prints perfectly but i get an error message saying "unknown device" when i want... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
