Question about HP Officejet 5610 All-In-One InkJet Printer
HP 5610 trying to align paper after replacing ink
I have a HP 5610 all in one and I just replaced my ink. The paper prints to align but when I put it on the glass, the window screen on the printer just says "aligning cartridges. please wait" what is wrong
SOURCE: Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
Posted on May 27, 2008
  • 54 Answers
SOURCE: Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
Posted on Apr 14, 2009
efs_perpends
  • 1996 Answers
SOURCE: aligning cartridges, please wait
Pressed ok more than once to start alignment??
Have you worked through this page already? And you tried the "Bypassing the print cartridge alignment" solution? See HP's solution here. Make sure you don't have photo paper or colored paper in the input tray when aligning...
When you perform the reset, did you unplug the data cable (usb) as well as the power, and wait a few minutes? Try leaving both data and power cables unplugged for 1/2 hour and then resetting, and make sure you complete the power cycle by pressing start copy color. Link here.
If none of these steps work, try removing and reinstalling the cartridges, and if that doesn't help, here's a last ditch fix that may work in your case.
Otherwise, I'm afraid service is the answer...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 23, 2009
  • 83 Answers
SOURCE: after replacing the ink cartridges and placing the
please check if all the wires are conneced properly and repeat the procedure again
Posted on Jul 04, 2009
ThiruBulls
  • 103 Answers
SOURCE: Printer will not align
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 27, 2009
Ink cartridge doesnt any help
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on.Figure 1: Press the On button to turn the product onc00442142.gif1 - On buttoncaution.pngCAUTION:If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One.Figure 2: Open the access doorc00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.Figure 3: The print carriagec00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper positionc00442144.gif1 - Print cartridge slot for the tri-color print cartridge2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Step two: Install the new print cartridgeBack to top
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.Figure 5: Remove the tapec00442146.gif1 - Copper-colored contacts2 - Plastic tape with pink pull tab (must be removed before installing)3 - Ink nozzles under tapecaution.pngCAUTION:Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Insert the print cartridgec00442148.gif
  3. Close the print-carriage access door.Figure 7: Close the access doorc00442149.gif
Step three: Align the print cartridgesThe HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. Use the following steps to align the print cartridges from the control panel.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray, and then press OK .
  2. The HP All-in-One prints a print cartridge alignment sheet.note.pngNOTE:If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  3. Lift the lid. Place the top of the alignment page face down in the left front corner of the scanner glass. Close the lid.Figure 8: Load the alignment sheet on the glassc00443602.gif
  4. Press OK to begin the alignment.
  5. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Oct 28, 2011 | HP Officejet 5610 All-In-One InkJet...
I have two cartridges in my 5610 a #22 color and a #27 black. I received a low ink message, but didnt know which one was low. I noticed that the most recent Word document looked fuzzy so I replaced the...
Hi
You can bypass the alignment on 5610 by pressing ok to start alignment
and then cancel
after that check by printing a document if your cartridges work fine if not
you can refill them with this easy and cheaper method
Jan 19, 2011 | HP Officejet 5610 All-In-One InkJet...
I installed a new printer cartridge. The alignment page printed out but I threw it out. I didn't realize I would need it for any reason. How do I align my cartridge without the paper.
Every HP I've owned has printed the alignment page until you scan it. Just plug in the printer, power it up, and check it out. If that doesn't work, try removing the ink cartridge, and reinstall it. One way or the other, I'm sure the HP will print a new alignment page.
Carl
Dec 30, 2010 | HP Officejet 5610 All-In-One InkJet...
I am aligning paper after inserting an ink cartridge. However after printing the alignment sheet and putting it under scanner glass it says "Alignment failed or no alignment paper present" help?
Hi
In order to have a succesfull alignment You need to have
good quility of printing
Replace and the other cartridge or try cleaning it frmo maintance menu
on your printers menu
But you have alwaeys the choice to cancel allingment by pressing cancel button
Pls Vote us to keep us alive
Nov 16, 2010 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 5610 All In One alignment cartridges and no printing
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab101
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
My Officejet 5610 will feed the paper but no ink will be on it
hi,
ab103
Jun 17, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer will not print after reinstall of software to macbook
yes ..if the sensor detect that there's is no ink or low ink..it display an error on the screen ..
to determine the status of the ink..
goto your desktop ..
click the printer driver software and select ink status..
good luck.
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
HP J4580 Printing blank pages
fist click the start menu
and click the printer and fax
and select the hp printer and rith cilck the proparties and seat the print colar coular that time
select only black...............ok
Apr 08, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C5280 printer - 1 month old not printing correctly
Usually this problem is indicative of a clogged nozzle. I'm not sure about the track record of the Photosmart C5280 (a lot of Epson printers have this problem, and you just have to keep replacing the ink cartridges). I'm going to assume you tried this, but go ahead and run a few cleaning cycles on the printer, and see what happens.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
174 people viewed this question
Seeker5211
Seeker5211
