Don't have floppy disk drive but I get floppy diskette se failure
Don't have floppy disk drive but I get floppy disk drive seek failure
  • fann987 Sep 26, 2009
    I have spent 3 months seeking answers to this problem and you took care of it thank you
    President:
  • 2,600 Answers
Go to the control Panel > Device Manager > scroll to drives, right click on "A" drive and disable it. You can also go into the computers BIOS settings....usually the Delete key when you see the manufacturers splash screen on boot up. When you are in the BIOS, go to the computer peripherals and disable the A drive if it is listed. Hit F10 and reboot.
Posted on Sep 25, 2009
Testimonial: "It was right on you were right on target "
  • 284 Answers
Have a look in your BIOS settings.
When you first boot you should see a message like press Del to enter setup. It could be another key like F2 or something.
In any case when you get in there you will have to dig around a bit as all pc's have these opetions in different places. You should be able to find an option to disable the floppy controller or mark it as not installed. You will probably find that it is set to automatically detect at the moment.
Just save your settings on the way out.
If you can't find it have a look through *********** board manual. It will describe where to find the settings. If you can't find your manual you should be able to find it online. Otherwise post again here with the exact model of your computer or mother board and perhaps someone else here will help.
Hope this helps
  • 557 Answers
Need to go into the bios and disable seek floppy drive. I believe on a Dell machine hitting the F2 key as soon as you start to boot grts you to the bios.
Floppy diskette seek failure
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
Dell optiplex 745 Floppy Diskette Seek Failure
how to solution. Dell optiplex 745 Floppy Diskette Seek Failure
Jan 20, 2012 | Dell Computers & Internet
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Black screen with Diskette drive 0 seek failure on it. pressf1 to continue, f2 to enter setup
diskette drive o or disk drive o? f2 to enter bios check boot options to boot on drive o [hdd-0], most boot options go floppy,cd-rom, hdd-0
Feb 04, 2010 | Dell Inspiron 530s Desktop Computer
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Jan 03, 2009 | Dell Dimension E310 PC Desktop
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
767 people viewed this question
David Payne
David Payne
