Question about Kenmore 57029 Side by Side Refrigerator
Ice Maker does not work.
This is on a Kenmore 27' side by side with ice & water through the freezer door. Model # 106.9537682
The water does come to the water dispenser, but does not come up to fill the ice maker.
  • 832 Answers
Check the line going to the ice maker for clogging.
Posted on Oct 07, 2009
Kenmore Model:106.56612500 side by side refrigerator ice maker not working .Possible water valve ,possible ice maker ,possible frozen water line .Ice maker is in the the freezer box not the door What is...
cheapest and up,, check for a frozen water line, defrost the entire unit, any of the components can be iced up, once defrosted,, if you still have a problem, then check the inlet valve ,
Jul 22, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
I have a Kenmore side by side 26' model 596.50692000. The unit is cooling however, the lights in the freezer side and the dispenser for ice & water outside the lights do not work but the water...
in the past i have seen this happen when the ice ben is emoved and the drive impeller is not seated properly usually due to ice ect. Its a pain but take out the ben and see if the motor turns normally. you can hold the door switch closed by hand and have someone push the button for ice if the motor turns you have the problem i have said. If not your door switch is bad and needs to be replaced it controlls the power to the bulb and the ice maker motor. You can pop the door switch out with a flatblade screw driver but have a replacement on hand wire plug into the back of it the switch is an on off switch. Make sure you unplug the ref first electricity bites...
Aug 08, 2010 | Kenmore Refrigerators
Ice maker stopped working suddenly. model no 106.56646500. Water is getting to the door but not coming out of the tube to the ice maker.
If you are sure the tube is not frozen the replace water valve. Also put 120v to the freezer water valve side to so if water goes up to the ice maker.
Mar 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Kenmore 57029 Side by Side Refrigerator Logo
387 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
