Question about Sony Cyber-shot DSC-M2 Digital Camera
C:32:01 system error , appears on My Sony Cyber-shot DSC-M2
When i press to play on video ,system error & c:32:01 shows up on the screen.everything else works properly.
Thanks for any help i can get.
  • 3006 Answers
SOURCE: Sony Cyber-shot DSC-T700 system error message
C:32:01 is a "disk format error". It means that your memory card is most likely corrupted.
First, remove the memory card and visually check that the electrical contacts are bright, clean and not greasy. Do not touch the contacts with your bare skin, use a cotton bud moistened with alcohol or methylated spirits if they need cleaning. At the same time, check that the lock switch on the MemoryStick is fully unlocked. Slide it fully to locked and then fully back to unlocked.
If the contacts and lock switch are fine then you can try reformatting the MemoryStick using the "Format" command in the camera menu, do NOT do this on a pc/Mac or in an external card reader. If there is an option to "Full Format" or "Quick Format" choose the full option. Note that any stored images will be deleted, but if you have suitable data recovery software they can still be recovered afterwards as long as no new pictures are taken which overwrite the data.
If that fails then try another MemoryStick in your camera. If the fault remains then the camera is faulty and must either be sent to a Sony Service Centre or replaced. Your camera may still be under the manufacturer's warranty, if so repairs will be free.
I hope that I have been of some assistance; please take a moment to rate my answer.
Posted on Sep 24, 2010
Testimonial: "Excellent, precise, accurate advice, which solved the problem. Gratitude and admiration "
  • 3 Answers
SOURCE: Sony Cyber-Shot DSC-W120 Flash Error
sony cyber-shot flashing solution is here plz contact me my name is ashraf khan my contact number is +919464631786
Posted on Nov 17, 2010
SOURCE: problem with sony dsc-w30 cyber shot flash
I found this solution in Yahoo Answers. go into the Setup Menu and find "Initialize". Select Initialize to reset the camera adjustments. Then try using the camera again.
Posted on Feb 17, 2008
  • 10 Answers
SOURCE: Change language display on Sony Cyber-shot DSC-W220
try under the settings menu
Posted on Jul 19, 2009
SOURCE: my sony cyber-shot DSC-W70 is flashing an error
Click Menu
go to setup
then go to setup 1
and go to initialize
then click ok and then ok again
put in the right date and time then
click ok
That should fix your problem! ;)
Posted on Jul 27, 2009
  • 2185 Answers
Would you like to open your pictures from your Sony Cybershot to your computer? Your cybershot cam is usually plug and play so you dont need a software for that. All you do is to plug in your camera to your computer's usb port using the usb cable. When the computer detected the new usb device, open a Windows Explorer. Right click your windows Start button, and choose Explore. From the list of Drives from the left, you need to find the Drive letter associated with your camera. Just click on that and it will show you the files on the right. The pictures are located somewhere inside those folders. You just need to click and drag them to your computer's local drive.
Should you have any questions, please let me know. Good luck!
Posted on Nov 13, 2009
0 characters
1 Points
C:32:01 system error , appears on My Sony Cyber-shot h-20
I resolved the C:32:01 system error I had on my DSC-H20 when trying to shoot video, by using the camera's memory format option :
-turn camera on
-press menu button
-scroll to toolbox icon
-press center button on wheel
-scroll to "memory stick" tool menu
-highlight "Format"
-turn camera off and back on
Aug 07, 2010 | Sony Cyber-shot DSC-M2 Digital Camera
Getting error E9101 with my w55
The error shows that(Abnormality when flash is being
charged.) the problem in in FLASH UNIT, it needs replacement, the part number is given below according to the model number you mention DSC-W55 Part No. 1-479-663-31 Description (FLASH UNIT).
Thanks for using ifxya.
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
hi, i have this problem with DCS-Hx1,
so you can format your internal and  card slot of your device to solve this problem,
Jun 11, 2009 | Sony Cyber-shot DSC-M2 Digital Camera
Press MENU. Select the toolbox icon. Select the "A" icon. Select the desired language.
Mar 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I have downloaded videos to my computer (Windows XP) from a Cybershot DSC-H5 and the videos won't play when I click on them. I get a fatal error that tells me to reinstall the product. I have deleted the...
Convert the video format at first,
Video Download Studio from can help you with this very well.
hope it can help you more or less!
Dec 26, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Sony cyber shot 7.2
    Mostly this symptom shws in two ways First is lens and second is main board.Just try it as i said. First dont turn the power on just press PLAY button from which u see the pics.If it turns on and you are able to see picture display on the LCD  then switch it to pictur taking mode.It means that the problem is in lens.And in doing this procedure it shows nothing on the lcd and not go to play mode and message "TURN THE POWER OFF AND ON AGAIN"appears Then the problem is in main board.
Thanks for using fixya.
Nov 02, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Sony Cyber-shot DSC-M2 Digital Camera Logo
2,114 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
