Question about RCA 25202RE3 Corded Phone
Can't hear my phone ring when incomming call comes in, on either line. think i hit DND button and don't know how to disable it
  • 832 Answers
Disconnect the phone to reset it. Then, reconnect it, and start all over. Press exit button to return to the phone setting menu. Press Menu button,. Use 5 or 6 to scroll to Answering Sys. Press Sel/Save button. And so on.... (This is in your manual, If you have it) If in case you don't have. Just download it from the internet at the following address ------- http//www.retrevo.com/support/RCA-25202RE3-telephone-manual/id/28/2878ag115//5/2/
Posted on Oct 05, 2009
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
How do I remove "Do Not Disturb" from the readout so phones will ring for incoming calls?
What model Uniden phone do you have? Most of the Uniden phones that support Do Not Disturb have a DND button on the base. Press and hold that button to toggle the feature on and off. (If the answering system was off, it will turn on when the DND feature is engaged.)
Other Uniden phones have a Silent mode that is enabled/disabled by pressing and holding # on any handset when the phone is in standby.
I hope this helps.
Apr 15, 2015 | Uniden Lands Phones
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
My Norstar Phone Won't Let Me Pick Up Incoming Calls
Make sure they are Line Buttons, do FEATURE * 0 then press buttons to see what they are/do
Or maybe the key pad inside has failed.
Mar 04, 2013 | NorStar Lands Phones
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Phone wont ring on incomming calls?
Could be two things, first is DND or do not disturb. Make sure that its turned off by either pressing the DND button or feature #85.The second is that the ringing wasn't turned on in programming.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Mar 26, 2009 | NorStar M7310 Corded Phone
Cisco ip phone 7940 does not ring for incoming calls.
It sounds like you have enabled Do No Disturb accidently. This can be turned on and off by pressing the DND softkey button along the bottom of the LCD display. You might need to press the 'more' softkey to display all options.
Jan 27, 2009 | Cisco 7940 IP Phone
Nec dterm80
Another solution is to pick up on intercom and dial 4 then 2 and hang up. That is the default DND cancel code. It can be used form single line phones within the system as well.
Oct 03, 2007 | NEC Dterm DTP 16D-1 Corded Phone
RCA 25202RE3 Corded Phone Logo
263 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
