Question about HP Pavilion Elite e9180t PC - 3.00 GHz; 1.5TB HD; 8GB Memory PC Desktop
My e9180t froze during first startup during the performance check
My e9180t froze in startup while the computer was checking performance. The instructions say specifically it will take UP to 20 minutes while the computer is still processing after 30 minutes. I did not change a language and the instructions say not to turn the computer off. What do I do?
  • 98 Answers
Restart it. It will be fine. If not . do a restore.
That what I do . I have a HP a730n.
Ken
Posted on Sep 25, 2009
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
Restarts automatically
If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. An error message may appear on a blue screen when the computer restarts.
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advancedtab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If theAutomatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
I hope this has answered all your questions. If you have any other questions, please contact us at info@custompcrepair.org
Mar 16, 2011 | Microsoft Windows XP Professional
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
My computer needs check up because very slow and lot of programs are in trouble during when i open my computer?
hi, the best thing to do is to uninstall the programs that consume more RAM memory and then to perform disk clean up with disk defragmenter on the harddisk
Jun 20, 2010 | ASUS Eee PC 900 PC Notebook
Acer Aspire 5740 works very slow
It seems that your computer is loaded with a lot of programs during startup. This means that before windows can formally start, it has to load all those software into memory which can readily translate into slow performance.
To boost your computer performance, you have to decide which software to load at start-up (or boot time) and which should be loaded when necessary only.
To make this easier, I recommend that you download "CCleaner" software, a free software that can manage all these. With CCleaner, you can easily "disable" a software that is configured to load at startup.
These is no risk in unloading a software from startup since you can just open them when you need it. Startup programs comsume a lot of resources making your system to perform slowly.
Also, with CCleaner, you can cleanup the registry with all the mess that your programs do.
You can download it HERE.
Jun 05, 2010 | Acer Aspire 5610-4648 Notebook
Computer running slow stuff keeps popping up
Your pc is infected. Go to -  http://www.avast.com/  - (antivirus) and -  http://www.safer-networking.org/en/download/index.html  - (antispyware) and Download (as in Save, not Run) the installers. Disconnect your pc from the internet (unplug the lan cable, shutdown the wireless or unplug the modem), close all your present (and clearly useless) security software and uninstall them,  launch the installers that you downloaded (Avast first - during install you will be offered the option to perform a boot scan - take it) and follow the instructions. Once the installs are over connect your pc to the internet and reboot once more. You will have to manually update Spybot (the link is on its main windows) before launching a full scan..
Nov 21, 2009 | E-Machines eMachines Desktop PC
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
Computer is TOOOO SLOW
probably due to all of the stuff in your startup folder a new pc comes with. the less stuff in your startup the better. you may need a memory upgrade of 1GB or less. I would go at least to 2GB of RAM
Jan 12, 2009 | IBM ThinkPad T60 Notebook
HP Pavilion Elite e9180t PC - 3.00 GHz; 1.5TB HD; 8GB Memory  PC Desktop Logo
116 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
