Question about Lenovo ThinkPad T61 Notebook
My T61 won't power on
My T61 won't power o. What should I do? It is a new computer from work, and I have never had this happen before. Thanks
    President:
  • 2,600 Answers
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Posted on Sep 25, 2009
    President:
  • 1,187 Answers
Do these non-destructive steps:
1. Remove the battery from the laptop
2. Plug in power supply
3. Turn ON laptop (it will startup)
4. Logon to Windows and allow it to "settle"
5. Insert battery (with Laptop poer ON and Windows running)
6. Allow battery to charge for a few hours
*done*
Posted on Sep 26, 2009
  • 496 Answers
Check all your cables and battery, if thats all fine check and see if removing the hard drive helps, it might be bad, if that wont work move on to the memory and remove that untill you get somewhere i had a similar problem after i removed my hard drive it booted just fine minus the hard drive
Why won 't computer communicate with code checker
Check the cigarette lighter fuse. This is what powers the DLC. If the fuse is good, check and see if the lighter works. If not, you have a bad wire. Code readers have to have power from the car. Most scanners have there own power and will read the computer, unless the data wire is bad or the computer is bad.
Mar 28, 2015 | 1995 Buick LeSabre
Arris WiFi Modem to lenovo thinkpad t61
As it works ok on your other devices then it may be the software on the T61. Try going to devices - wifi and update the driver.
Jan 28, 2014 | Arris Computers & Internet
Keyboard freezes up, it won't type on ThinkPad T61
Do a full scan with your antivirus, if okay! try a system restore by taking computer back in time before this became a issue.
Apr 07, 2012 | Lenovo ThinkPad X200 - Intel Centrino 2...
On power up, t61 shuts off b4 PW entry
when windows xp comes on hold down your enter button and your computer will stay on okay
Mar 29, 2010 | Lenovo ThinkPad T61 Notebook
Thinkpad T61 Battery Problem
You probably should get a new battery or at least a good used one.The battery icon is saying 100% but its at 0% because the battery is malfunctioning.
Oct 05, 2009 | IBM Lenovo ThinkPad T61 6466 Notebook
Lenovo t61 couldn't find any wireless network from 2 days ago, it was good before and used to get this problem for one day, i didnt do anything and just waited it was ok. this time it doesnt seem to be ok...
The network card could be shot for wireless it happens on older computers.. On ebay you can get a wireless USB for 10 bucks, have one my self, works great comes with drivers, nice and fast!!!
Aug 10, 2009 | Lenovo ThinkPad T61 Notebook
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
I have an IBM T61 that will not power on.
Power supply may have been hosed. Another thing to try is to plug the A/C adapter in but do NOT have a battery connected. If it powers on then there might have been a problem with the both batteries. Also be sure nothing else is connected to the computer's ports. Especially any external video devices.
Mar 04, 2009 | IBM Lenovo ThinkPad T61 Notebook
Thinkpad T61 shutsown problem after installaing XP pro
Getting into Windows Safe Mode when you cannot boot after installing a new device or driver. ... From Windows Safe Mode click Start / Shutdown and restart the computer.
NTLDR is missing If you are attempting to install Windows XP or Windows 2000 and are receiving ... After the above two files have been copied, remove the floppy diskette .
How to shut down / restart the computer with a batch file. It may be necessary after a batch file is completed its copying or installing ... Microsoft Windows XP includes a new shutdown command that will enable .
Read and follow instructions/Good Luck, Please dont for get to Vote/Thank You.
Dec 08, 2007 | Lenovo ThinkPad T61 Notebook
Lenovo ThinkPad T61 Notebook Logo
1,510 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
