Question about Intermec EasyCoder 3400 Thermal Label Printer
Printed fine on Tuesday, now unit will not print; tried fresh xp pro install and returned dip switches to factory. Tried x2 serial cables. Can you suggest changes for dip switches?
Following the steps outlined in the wizard I did manage to install the print server utility on one of our computers (my wife's notebook / Windows 7) and get it to print successfully. However, when I...
Oddly enough I did almost the exact same thing. I sucessfully installed and printed a test page on my wife's Win7 notebook, and was almost ready to install on my XP Pro notebook and daughter's computer. When I got it installed on my XP Pro notebook, it failed. Since then I have been trying to get the network to see it. It doesn't work! Even when I hardwire plug directly into my router, the router does not acknowledge something is plugged in. To eliminate the possibility of faulty networking cable, I used the same port and cable for my Apple TV unit. It worked just fine. The the TEW-MP1U appears to be a brick at this point. It only gives a green status light, my appears to have no network functionality any longer, wired or wireless. What gives?????????????
Apr 02, 2011 | Trendware (TEW-MP1U) Print Server
Dymo Labelwriter 450 Turbo won't print on Windows XP Pro system. Installed drivers & software from CD provided (Ver 8.0) Looks like it installed cleanly, but noticed that the printer didn't acknowledge...
Uninstall the driver, remove any trace of the install from the system (as much as is possible). Whent his gets messed up it's really hard to get working on that machine again under XP. Aquire the printer through add printer and detect not the software on the CD, install the driver using the inf file on the Cd. Now reinstall the printer software using USB or serial as an option, when prompted select custom install and no driver. If you have it setup on another machine this also works, but acquire the printer through network neighborhood instead of using add/remove programs.
Apr 06, 2010 | Dymo LabelWriter Thermal Printer
Paint Shop Pro will not respond AT ALL!
not a hardware or major software prob, but see that if any other software have the same prob...?
you will have to scan your pc through a best virus cleaner or remover. then will have to install a fresh O.S, and then install Paint Shop Pro X2, it will run faster then before..
take care
shafky
Jun 20, 2009 | Corel Paint Shop Pro® X Full Version for...
Strange Printer Issue - HP Laserjet 2600n
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Apr 23, 2009 | HP Color LaserJet 2600n Printer
Epson TM on Windows XP with serial
you need to use the printer cable that was design for the printer. if you don't have the cable anymore, then you have to take the commercial cable apart and reconfigure in accordance to page 43 of the manual call outs.
Besides the cable, the printer software is only good for Windows 2000. Windows XP will not work unless Epson provide you with the printer driver. (which I did not see on the website).
all in all if you must use this printer with Windows Xp. you need to create a file in Autoexec.bat to enable the printer and allow the USB to connect to the printer.
that is going take time to do. if you need help on that. please post the request here.
Thanks
Dec 03, 2008 | Office Equipment & Supplies
Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Sep 19, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Only prints one page
You could try using these drivers on the Hp.com. These drivers were from March of 2007.
This was listed at Officejet K550. They didn't have a Pro Printer listed. If there are any letters after the model number you should go to that page instead.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=501369&lang=en
Jun 14, 2008 | HP OfficeJet Pro k550 Printer
C3180 will not print as error occurs even when installed
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
The self-test report prints, containing the serial number and service ID.
This should tell you if it is a problem with the unit itself, or with communication between the unit and your computer.
Feb 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
New Kodak EasyShare 5100 will not print!
You might have to reformat your hard drive as there is something in your OS that is hindering the printing.
Feb 01, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
OKI ML280 serial card installation
I believe on the top of the printer towards the back is a panel with a single screw. Under here are dip switches to set the printer.
Jun 18, 2006 | OKI (09002353) Serial Adapter
Intermec EasyCoder 3400 Thermal Label Printer Logo
27 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
