Question about Akai PT5492S 54" Rear Projection Television
WHEN I PLUG IN TV THE TIMER LIGHT IN THE FRONT COMES ON BUT THE SCREEN WONT COME ON AND I CAN HEAR A TICKING NOISE
  • 476 Answers
The ticking comes from overcurrent circuit protection there are several areas inside the tv that could be causing this. The most common are the horizontal drive and output circuit and the power supply. If you call your area service tech he can give you a good idea on what the repair costs will run.
Posted on Sep 25, 2009
Car won't start and makes a ticking noise
CHECK IF TURN SIGNALS WORK, USUALLY ON GM CARS IF A BULB IS BURNED IT WILL TICK FASTER, IT IS AN INDUCATION OF BURNT BULB - COULD BE FRONT OR REAR
May 19, 2010 | 1999 Chevrolet Cavalier
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
Ignition coil light came on, ticking noise now car wont start
it sounds like the glow plug relay has packed up you could try and get a second hand one this would be a cheaper option than buying a new one.
Oct 08, 2009 | 1999 Ford Escort
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Ticking TV
This noise come from a component that needs soldering, probably comes from one of the terminal were by any reason is not doing good contact. Or is the flyback, a component that uses high voltages to accelerate the rays inside the tube.Unfortunately, is not a big deal for a regular technician, but is a big trouble if you try tio open the TV. Is very risky because the mentioned component, along with others usually they work at ranges ol voltages of 50,000 or more volts. Although the current is not much, the shock is very unconfortable. Don't try, take it to a tech.
Nov 23, 2008 | Philips Magnavox TS3260C 32" TV
Green flashing power light and ticking noise but wont turn on
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
Jul 25, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Ticking noise from TV - Sony 50' rear projection 1080p LCD
The problem is ht leakage . remove the ultar cap of the tube and clean both the tube and cap with wd 40. then reinstall cap using some silicon glue.
this will correct your fault.
Jul 11, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv won't turn on
Most likly it is a problem in the power supply regulator circuit. pretty common for Toshiba TV sets. If you know about TV serviceing, first thing to replace would be the regulator IC as that is the problem 80% of the time. if that does not help then you will need a schematic to trace out the regulator circuit. Good Luck PS please dont forget to rate this thread.
Oct 19, 2006 | Toshiba 34HF84 34" TV
TV, i plug it in, turn it on, no image, "on timer" light comes on.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Aug 07, 2006 | JVC AV-27D302 27" TV
Akai PT5492S 54" Rear Projection Television Logo
585 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
