Question about Ovens
The model number on my kenmore ovens owner's manuel says 911.48485 911.48489 I can't find that model number anywhere online My ovens are showing f0 code. They did show f7 but changed. HELP I need to get it fixed!
    Scholar:
  • 30 Answers
Don't replace anythingf, try this! The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. There, problem solved.
Posted on Nov 24, 2009
    President:
  • 497 Answers
Kenmore is a product of sears, i've had issues trying to find codes for people in the past. The only thing i can tell you is call Sears. They for some reason like to keep the codes hidden from people in need of help.
Posted on Sep 25, 2009
What does an error message "F0" mean for kenmore model 911.41185991?
for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
Jun 21, 2010 | Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Broken oven switch, Magic Chef gas oven
http://panjiva.com/Manufacturers-Of?q=magic+chef+spare+parts
http://www.partselect.com/Magic-Chef-Parts.htm
It;s a global economy now, and you can order and buy spare parts from anywhere for anything. please use these links provided to source your part,and ship it back to the mother land, Aoteroa.
  1. Find the model number on the appliance to be repaired. Look for a gray or silver label on the appliance that lists the model number and serial number. If you cannot find the tag, check the locater featured on PartSelect.com. Click the link marked "Need help finding the model number on your magic chef appliance?" Then click on the type of appliance. The guide will show possible locations for the identification label, along with a sample label for visual reference. The URL is listed in the resources section below.
  2. Use the part number to make ordering simple. Look closely at the part you intend to replace. A part number will be printed or inscribed on any part that is large enough to display at least six digits.
  3. Order parts from appliance retailers. Call local USA appliance shops and ask if they sell parts. If so, get a price quote for your part and ask if it's in stock, or how soon it could arrive.
  4. Order from online parts dealers. Use your appliance model number and part description or part number to check online parts dealers for prices and ship times. PartSelect.com, RepairClinic.com and AppliancePartsPros.com all sell Magic Chef parts online. The Magic Chef website may also be able to provide needed parts. It also lists owners manuals, warranty information and installation instructions for their appliances (see Resources).
  5. Compare prices and order fulfillment times between local retailers and online dealers. Most online dealers will offer lower prices. A local dealer may have to wait for your part to ship from their supplier. The shipping time between local and online dealers may not vary.
Apr 27, 2010 | Magic Chef 9122 Gas Single Oven
New stove with no owners manuel
whut is the brand and model number, number will be usually on frame u can see by pulling out lower drawer, if i have that number i can search online or go to the manufactures/makers website most have downloadable or printable manuals let me know if this helps
Feb 14, 2010 | Ovens
Kenmore double oven keeps beeping and shows error code FO
Hello there:
F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Dec 31, 2009 | Ovens
Melted tin foil on oven bottom
in your owners manuel is stated to not put tin foil on the bottom of the oven.. depending on your model you may be able to replace the bottom panel.. however you can still use the oven without any problems.
Jan 20, 2009 | Kenmore 30169 Electric Single Oven
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
Kenmore model # 911-494-79790
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
May 11, 2008 | Kenmore 30169 Electric Single Oven
Ovens Logo
103 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
