Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
My chain came off. How do I get it back on? - Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
    President:
  • 2,220 Answers
Use page 25 of this downloadable manual as a guide.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=359&types=O
Loosen your tension adjust before attempting to fit the chain on the bar.
HTH
Lou
Posted on Sep 25, 2009
My Ryobi 10532 chainsaw chain will not turn. The chain lock is off, it is a new chain. I replaced the old chain as it caught in a stump and stopped turning
pull the chain clutch back towards the handle
it is not a chain lock but a clutch release that stops the chain from turning
pulling it back engages the clutch to drive it
Jul 13, 2016 | Ryobi Garden
How easy is it to fit a cam chain and link in sit to a Honda CB 750 1994. and what is the main problem with a rattling chain on one? is it mainly the chain for the cam, or the lower drive chain for the...
eaasy take off the timing /rocker cover and the top chain guide exposing the top of the chain undoo locknut and back off tensioner then break chain after tying both ends with cord so they cant fall in then splice the new chain onto the old and wind it through taking care to not let it jump teeth on timing wheels, detatch old chain from the new one, swage rivet pin in join of new chain crank engine by hand with a spanner two full rotations to check for valve piston interference and reassemble tighten tensioner until chain feels tight then back off 1/4 turn put back upper chain guide and bolt down rocker cover and you are done easy
Oct 21, 2014 | Motorcycles
How do I put the chain back on a chainsaw?
you need to loosen the nut on the side of the chainsaw and then take the cover off. Remove the bar and take the chain off. Then put the chain back on the bar being careful about the direction of the chain. Place the chain back over the sprocket and lower the bar back onto the plate making sure the hole lines up with the adjusting mechanism on the cover. After you line up them up put the nuts back on and loosely tighten them. Adjust the chain where it is almost tight and then tighten up the nuts.
Sep 20, 2014 | Poulan Garden
How do you fix the chain
Remove cover on the chain side of the saw. Loosen the two hex nuts that hold the bar onto the saw. You will need to loosen the tightener screw also. Place chain back onto the bar making sure the chain is positioned properly in the sprocket at the rear of the bar and just reverse the directions. Tighten the tightener screw until the chain is tightened leaving a little slack, then tighten the two hex nut. Replace the side cover. When you pull the chain down away from the bar, it should have just a bit of slack not tight. This allows the chain to turn without a lot of friction. I hope this helps.
Jan 26, 2014 | Homelite Garden
Chain is sticking to back sprocket and making my bike **** when i accelerate
Sounds like the chain is worn out and needs replacing if there is no more adjustment!
A good idea is to replace the sprockets at the same time, as they wear along with the chain, and will cause a new chain to wear out sooner.
Nov 19, 2013 | Suzuki RF 600 R Motorcycles
Chainm has popped . How do I put back on?
On the right side of the saw, where the chain disappears into the housing, there should be one or two nuts. These are what hold the Bar and Chain retainer plate on. Remove these two nuts, and the plate, the Bar, and the Chain will come off.
Now, just to put the chain Back on to the Bar, all you have to do is to LOOSEN these two nuts, and either right between them, or NEAR them is a FLAT-HEADED SCREW. Turn this screw to either LOOSEN, (retract) the Bar, or EXTEND the Bar. So, retact the bar, which loosens the chain, put the chain back on the bar, slowly extend the bar, by turning the screw, so that the chain gets tighter, then tighten back up the two nuts.
The chain should have a small amount of slack in it when you are finished. If you tighten it up too much, then it won't freely move, and will prematurely wear out your bar.
Good Luck.
Jun 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
How do you rePlace the chain on the 455 rancher?
You take the chain cover off of the bar. It is two nuts. Take them off and the cover will come off. Slide the bar toward you and the chain will become slack. You can then slide off the chain from the sprocket. To put a new one on. You will need to turn the chain adjustment back all the way to the left. Then put the chain back over the sprocket, then onto the bar. Put the chain cover back on and tighten the chain back up. Then tighten the two nuts back to tight.
Apr 03, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
The chain has slipped off my McCulloch 839 chain saw- model no 22600038-53. How do I get it back on?
At the right side of the saw there is some bolt for the gear cover so unscew them to get access to the chain blade adjustment.You will see another bolt that is holding the chain with the chain plate and has a 2" groove.This groove let you move the chain along with the plate back and forth to make the adjustments.
Thigh back the bolt once adjustments made and put back the cover.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 19, 2011 | McCulloch Garden
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
83 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
