Need gear wheels - Office Equipment & Supplies
  • jharris125 Sep 29, 2009
    It is an Olympia model 3825.
  • Ronald Park
    Ronald Park May 11, 2010
    Need to know type and model of the shredder.
  • 855 Answers
TRy going to factory-express.com That is the place I found that seems the best bet for you. They have a listing for your shredder which is a lot better than many of the places I checked out. So try them and Good Luck.
Posted on Sep 30, 2009
Diff ratio. On a 1994 toyota 4 runner v6 petrol ??
4x4, 4 cyl, 4.10 ratio, ABS 4x4, 4 cyl, 4.10 ratio, w/o ABS
4x4, 4 cyl, 4.56 ratio, ABS 4x4, 4 cyl, 4.56 ratio, w/o ABS
4x2 (3.90 ratio), 2 wheel ABS 4x2 (3.90 ratio),
4 wheel ABS 4x4, 6 cyl, 2 wheel ABS, 4.30 ratio
4x4, 6 cyl, 2 wheel ABS, 4.56 ratio 4x4, 6 cyl, 2 wheel ABS, 4.88 ratio 4x4,
6 cyl, 4 wheel ABS, 4.30 ratio 4x4, 6 cyl, 4 wheel ABS, 4.56 ratio
4x4, 6 cyl, 4 wheel ABS, 4.88 ratio there are a few options. you will need to figure it out or look at the code panel in the truck. if you want to figure it out. you will need to remove the cover from that axle and count the two ring gears and then divide the numbers to get the gear ratio. for example if one is 40 and the other was 11. would be 3.72. so here is the trick to counting the gears. they are covered in oil so have a pan ready when you pull the cover. and use a marker or crayon and mark a tooth on the gear ring. then count the gears and you will know where to stop when you get back to your mark. the little gear will be harder since its in the back. you might have to turn the wheels and you will need it in neutral and jack the rear end up. as always use jack stands to prevent damage to you or the truck..
Mar 20, 2015 | 1994 Toyota 4Runner
My scotts rotory spreader will not spin
The design is quite simple with one wheel driving a bevel gear in a gear box. If the wheel turns the axle shaft and the center pin in the spreader with the retainer/cotter pin does not turn it is likely something has failed in the gear box.
If both wheel spins and the axle does not turn than the drive wheel has disengaged the axle shaft and the cotter pin in the drive wheel needs to be replaced.
The compounds used in the spreaders are corrosive. Usually the gears and axle become bound due to corrosion. By oiling the bearings and wiggling the wheels they will free up,
Hope this helps?.
Apr 19, 2013 | Scotts Company 589384 Scotts 5000 SQFT...
How to change the tire on a schwinn loop
It's pretty straightforward changing the tires on the loop. I'm a big guy and the standard 65 PSI tires it comes with are ****. two blowouts already in the rear, most likely due to poor weight distribution. But Whatever the reason you have, here's how to change the rear tire.
1. You'll need to grab a 15mm wrench or socket & ratchet combo. Remember, righty tighty lefty loosey.
2. Remove the rear derailleur gear guard, it just sort of falls off. Store it somewhere safe until you're ready to reassemble everything.
3. Gently pull upward on the wheel once both bolts are removed. Carefully pull the derailleur away from wheel gears as you pull it upward and out of the gear system entirely.
4. Done with that part and the wheel should be out! Do whatever repairs that are necessary for the removal of the wheel, possibly changing a tube, I don't know. You needed it out, now it's out.
5. Reassembly is easy enough. Make sure the wheel isn't fully inflated while reassembling. The brakes on the Schwinn loop are tiny little things, you'll need to pinch to get it past where it needs to be again.
6. Move the derailleur gears out of the way while you move the wheel back into place, then slowly remount the chain onto the wheel gear assembly. It's very intuitive, you'll see exactly what you need to do here.
7. Throw that rear derailleur gears guard back on there, screw on and tighten those rear bolts and bam! Presto change-o! The tire is changed and you can feel a little more mechanically inclined for the day.
NOTE: Changing the front wheel is also a simple job. You'll use the same 15mm tool, except there are no gears to worry about. Cheers!
Jul 09, 2012 | Pacific International Schwinn Loop 7-Speed...
Front wheel gear not engaging
move wheels out to meet gear if gears stripped switch wheels from front to back
May 05, 2012 | Pentair White/Gray Legend Platinum...
As I shift the large gears I can't get into the mountain gear , it needs some adjustments and I don't know just how to do that. Chris
both the foot and wheel gear have two adj screws. turn bic upside down put gear in lowest setting turn wheel with foot peddle.adj front gear so outside gear or the side on the frame is bar-ly going to touch lever.do the same with rear wheel then move level to highest setting.and do the same this time the out side should bar-ly be touching the chain.after a few adj the gear should shift without any binning.
Apr 18, 2011 | Cycling
Won't just stay in one gear. constantly doing gear changes on its own. Hardrock. Rear set, reguardless of which front gear.
This happens when the back wheel is not aligned properly with the chain. As the wheel turns the chain is being pulled to one side causing it to slip to the next set of cogs. To solve the problem first you need to loosen the wheel by opening the 2 nuts on the axel. If the chain slips inwards towards the wheel you need to move the front part of the back wheel to the left from a view point behind the bike. If it slips outwards away from the wheel then you need to move the front of the back wheel to the right as viewed from behind the bike. When the chain and cogs of the rear wheel are lined up in a straight line the problem should be solved.
Dec 04, 2010 | Specialized Bicycle Components Cycling
The right front wheel will not turn as fast as the left; if at all. The cover behind the wheel has a tear in it. I have the part but cannot get any further than taking the wheel off. Please help. Thanks
Locate and remove the E-Clip that holds the pinion gear (the steel gear that drives the wheel) on the transmission shaft then remove the pinion gear. That is all you need to do to replace the dust cover
Sep 26, 2009 | Garden
Telescopic Steering wheel won't move down - I hear a gear spinning
Open the gear motor on the left hand side of the telelscopic assembly. Take the plate off held by 4 philips screws. Using a 10mm socket, remove the bolt holding the platic gear. Remove plastic gear and insert the reverse way. Over the years, one side of the gears get worn out.
Oct 27, 2008 | 1997 Lexus LS 400
Venta LW44 - KNocking sound and only 1 of the 2 wheels turn
This sound is could mean that the life of the gear has been used up.
This is a common problem. It is easily fixed for $10 + Shipping. The gear needs to be replaced. Try this link to have someone call you. abdistrsupport@gmail.com
Remove the gear and turn on the unit to see if the noise still exists.
  • If noise stops, the gear and coupling needs to be replaced
Dec 10, 2007 | Humidifiers
168 people viewed this question
k24674
