Question about Car Audio & Video
I need to install a 12 volt power outlet on my truck
I need to install a 12 volt power outlet on my 1978 jeep grand cherokee, but i dont know how to.
    Problem Solver:
  • 10 Answers
This should be a simple task for you since the cherokee already runs on a 12 volt power system. the easiest way to do it would be run a single pair wire from the battery itself to a 12 volt connector. there are harder, more detailed versions of this where you would need to dig into the fuse box, but if you are looking to power something low voltage like a gps, cell phone the first way will work.
you can buy the connector and wire with a fuse on it from any autoparts store. you will need to drill through your firewall and I would recommend a uni-bit or multi-bit to get through it. it will go right on to your drill.
Posted on Sep 25, 2009
My 1999 grand cherokee laredo stopped working. the battery died then recharged but wont fire up
I would buy new battery to make sure you have the proper 12 volt current at least , but need more info on the your jeep.
Jun 03, 2014 | 1996 Jeep Grand Cherokee
Fuse keeps blowing dash lights and tail lights dont work jeep cherokee sport 1999
There are several fuses involved. I need to know which one(s). As for the taillights, the primary power source is 20A fuse 17 in the power distribution center. The tan/blk wire connects to the headlamp switch which, in park position, applies +12 volts through 10A fuse 7 in the junction block to the left tail light. The headlamp switch, in park position, also apples +12 volts through 10A fuse 23 in the junction block to the right tail light.
I need to know which fuse is blowing the instrument lights so you will have to follow up
Sep 07, 2012 | 1999 Jeep Cherokee
I have a 95' Jeep Grand Cherokee Limited with a
Are you check your previoud questions: check_engine_error
Keep us updated.
Jun 07, 2011 | 1995 Jeep Grand Cherokee
On my 2000 jeep grand cherokee, my right brake light is not working even after I changed the light bulb. what should i do?
If you have a multi-tester and know how they work, you need to check the bulbholder to see if you are getting power to it. There should be approximately 12 volts at the holder.
Oct 18, 2009 | 2000 Jeep Grand Cherokee
2005 jeep grand cherokee
The washer pump is located on the washer bottle. Must check for power at pump when applying switch if no power (12 volts) check fuse or curcuit. If it has power replace pump. Also: if pump is operational check hoses for resteictions.
Jun 13, 2009 | 2001 Jeep Grand Cherokee
Horn doesn't work
get a 12-volt tester and check the wire going to the horn to see if there is power going to the horn if it is the horn maybe bad check all fuses first i hope i have been some help to you Michigan man.
May 08, 2009 | 1996 Jeep Grand Cherokee
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
