Question about Sceptre X9G-NagaIV 19" LCD Monitor
Monitor will not turn on
After power failure monitor will not come on
  • 2 more comments
  • sceptre help Jan 16, 2008
    my sceptre x9 monitor will flick on then turn black. can't get it to show anything on screen,although blue power light is on. Help!
  • Anonymous Apr 21, 2008
    can you pleaso show some images
  • Anonymous Aug 20, 2008
    unplug the monitor and replug it check the connection to the computer
  • knigher Nov 01, 2008
    Had a power outaga now monitor will nit turn on. Don't know what to do it is a emachine T3414
After power failure monitor will not come on again.
Posted on Sep 18, 2008
    Problem Solver:
  • 16 Answers
Replace the fuse inside the monitor it is on the left side if the plug
Posted on Dec 17, 2007
Why did my HP desktop turn off?
Bet you a cup of coffee the power supply has gone south. Common repair. Get another power supply and install in place of old one.
Aug 20, 2015 | HP Pavilion Computers & Internet
LG L206WU monitor will not turn on
The normal cause of power loss if a failure of the filter capacitors on the power supply board. Here is a link to information on the power supply board and the capacitors that need to be changed.
http://www.ccl-la.com/catalog/product_info.php?products_id=242
Apr 26, 2013 | LG FLATRON L206WTQ-BF Monitor
Syncmaster 2333sw
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply. C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed, replace them at once.
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-1-1.jpg
Jul 27, 2012 | Samsung SyncMaster 2333SW 23" LCD Monitor
Monitor does not turn on
The most common cause of power issues with that model is a dead power supply resulting from a failure in the capacitors on the power board. This is a very easy repair. You have to replace the 6 filter capacitors on the power supply board. The capacitors on the power supply board should be flat on the top and when they fail the tops will bulge showing failure. You can open the monitor up and look at the power supply board and check for the bad capacitors to verify the failure point. Here is a link to some information and parts kit to repair that board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=218
I hope this helps.
Jun 20, 2012 | ViewSonic Computers & Internet
My monitor goes off. When I turn the power off then back on, the screen comes on momentarily, then goes off again! The power light stays on during this.
It sounds like the backlight power supply is failing. It is a common failure for LCD monitors. The usual failures are blown transistors and blown capacitors. It can be repaired, by an electronics repair service. You need to weigh the cost of repair against the cost of purchasing a new monitor, to determine whether it is worth fixing or getting a new monitor.
Feb 22, 2011 | Hannspree Computers & Internet
Monitor won't come on
Most LCD monitors have common problem due to caps failure in the power supply, that will be the first place to check. Need to verify that you do have 5vdc and 12~18vdc from the power supply output.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 07, 2010 | Acer 22" X223w LCD Monitor
How do I turn the monitor in
It sounds more likely to have power supply failure if you hit the power button and it does not turn on.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply. You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 02, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
My Envision 7100 Stop Working
These are all some component failure problem in the monitor circuits. This may have been caused by faulty components or overheating of the components causing intermittent or permanent failure of some components in the circuits.This causes the feedback circuits to sense incorrect voltages or currents in the circuits and turn on the protection circuit. It may also cause total failure of the power supply circuit and a loss of power to the monitor. These units should be returned to dealers for servicing. Hope this helps you .
Jan 09, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
Dec 25, 2007 | Hanns.G Corporation HU-196DP LCD Monitor
There is power but no display
Your symptom is commonly caused by failure if the inverter circuit. It is made by Sampo. The inverter powers the backlights. Replacing the inverter is the first step to resolve the problem.
Oct 10, 2006 | MPC Computers AOC 7F 17" CRT Monitor
Sceptre X9G-NagaIV 19" LCD Monitor Logo
309 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
