Question about Brother MFC-9840CDW Laser Printer
Wrinkled envelopes Brother mfc 9840cdw
TOOK YOUR SUGGESTION, OPENED LARGE BACK DOOR. ADJUSTED GREEN LEVERS TO ENVELOPES. TRIED TO PRINT MY THREE ENVELOPES. WITH MY MFC 9840 IT WILL NOT LET ME PRINT WITH THE BACK DOOR OPEN. THE MESSAGE SAYS, "COVER IS OPEN". CANNOT PRINT WITH DOOR OPEN AT ALL. CAN YOU HELP? ANYONE?
Instead of moving the whole green lever to adjust that grey arrow to the envelope symbol, simply push the gray part that has the arrow on it. This will move the gray piece down to the env. symbol and will not move the green lever so you can close the back door. I used to have severly wrinkled envelopes. Now they print out perfect.
Posted on Oct 05, 2009
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
I have a brother HL-2140/2170W Monochrome Laser Printer and don't know if I can print envelopes from this printer. It doesn't appear to have an envelope feeder.???
It can cause creased envelopes when printing on envelopes......but if you consult the manual there are fuser tension adjustment switches that solves that for perfect envelope printing (Settings, A, B and Envelope).
http://www.iusermanual.com/printer/brother-mfc-9840cdw-multi-function-printer-manual.htm
hi at this above site you can download your user manual, this shows you in detail exactly how to print on envelopes.
below is a Brother "How to" It's very informative.
http://welcome.solutions.brother.com/BSC/public/as/nz/en/faq/faq/000000/000000/000063/faq000063_033.html?reg=as&c=nz&lang=en&prod=mfc9840cdw_all&Cat=103
Dec 20, 2010 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW not printing colours properly
Always use Brother toners. This is a common issue with cheap copies and remanufactured cartridges.
Jun 08, 2017 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW wrinkles envelopes. Brother says this is "normal", and that the only way to 'fix' it is to open the back of the printer EVERY TIME YOU PRINT AN ENVELOPE and make some kind of...
Problem Solved!
I have a Brother MFC-8480 DN all in one printer, copier, fax and scanner.
I discovered that envelopes wrinkle because users, like me, didn't know that Brothers built in a no-wrinkle, pass through exit for envelopes, labels and thick paper.
Envelopes were never to be printed by inserting them in the front and letting them wrap around a HOT roller and get cooked and wrinkled. The way it works:
An envelope is inserted in the front and goes straight out the back of the printer through an exit door, completely avoiding the hot roll-through mechanism.
Take a look. On the back of the machine is a large pass through exit door. Just snap it open. You will see one blue lever on each side of the opening. Snap them both straight down to the . . .ta da. . ."envelope icons".
Put three envelopes in the front and they will print straight out the back, perfect and wrinkle free. After printing your envelopes, snap the blue levers back up and shut the door. Takes about five seconds to open the door and snap down the blue levers down/up.
Happy envelope printing.
-Eric
Jul 11, 2009 | Brother MFC-9840CDW Laser Printer
When we try to print envelopes. It grabs the
Open the door on the back above the power cord. Rotate both blue levers all the way up so they change from "1" to "2". Wrinkle problem will be solved. This was in the troubleshooting section of the online user manual, page 95. You would think they would tell you about this in the envelope section of the manual.
Jul 01, 2009 | Brother HL-5240 Laser Printer
Envelopes all come out of the printer wrinkled
Open the back of the printer. You will see 2 little blue levers on either side. Put them in the opposite direction, that is, if they are up, snap them down. I dont know the mechanics of this, but it worked for me.
Nov 01, 2008 | Brother HL-5240 Laser Printer
Printing envelopes on HL4040CN
I just bought a HL-4040CN and all my envelopes wrinkled, regardless of the size, paper thickness or software settings (thin envelope, thick envelope, etc.). Here's how I solved the problem....Open the rear panel and you'll notice a small gray lever on each side, which is probably pointing to "A" on the scale (A, B, Envelope). Move both levers to "Envelope" and close the back panel. The troubleshooting manual says the levers should be moved back to "A" after printing the envelopes, but I left them in the Envelope position and can't see any difference when printing regular or test pages or envelopes, except the envelopes are no longer wrinkled. I called Brother and asked them if there was any reason why the levers can't stay in the Envelope position, and they told me they could be left there if it wasn't negatively affecting other documents. Now, I have a great printer that prints everything without any problems. Hope this helps.
Sep 08, 2008 | Brother HL-2040 Laser Printer
Brother MFC-9840CDW Laser Printer Logo
764 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
