Question about Sony Playstation 3 (PS3) Console
A blank screen
I played on Playstation 3 yesterday, everything was fine, had been fine since February this year. I'm using HDMI cable.
However, when I switched it on today, Green light came on but nothing was seen on TV; a blank screen; I also tried the AV cable and still nothing.
Any advice please?
  • potty37 Sep 25, 2009
    Tried the above instruction, still showing blank screen.
    to colinhaugen, sorry repeating, after tried your instruction, i'm still getting nothing, the same with sound. under the playstation, stiil have green light (not power switch). just passing more information to help to solve the problem.
  • 63 Answers
You probably need to reset the video. Here's what you do: Turn the PS3 off from ther back switch and then back on so that the light on the front is red. Then press down on the power button and DO NOT let go. Wait for it to turn green then beep and then go back to a red light. Then press the power button again. After you have tried that, either tell me it didn't work so I can offer more advice or tell me it worked. Thanks. :)
Posted on Sep 25, 2009
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Just bought a ps3 two weeks ago. Played games just fine and everything worked well. We watched a movie last night. Turned off the system and went to bed. The next morning we tried turning it on but it...
This may be a simple fix. Do you still have the original cable that came with it for the video OUT? Plug this back into your playstation and TV while leaving the HDMI cable connected.
check now both HDMI channels and AV/Composite options on your source selection this should give you the display,
Now what we need to do is setup your HDMI output again.
From the menu bar,
  • Go to settings
  • Display Settings
  • Video output settings
  • choose HDMI
if you have the choice to choose OK choose it. If your screen goes blank go through your HDMI channels again and if the Playstation screen is there then select OK,
Then you can remove the composite cable again
Jan 14, 2011 | Video Game Consoles & Games
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
Screen goes black
sounds like you're using an HDMI cable, and the cable is broken. That's exactly what happens when HDMI cables break, a few of those 0s and 1s don't make it to the TV every once and a while, and the TV goes black and the audio dies.
or
go to system update and choose online update. an optional ps3 firmware 3.01 fixes this issue
also, I had a similar situation a while back. Anytime I loaded any disk (game or movie) it would just go black and freeze. I had to do a system reset (where it reloads everything and you lose your data). You can back everything up before that and restore it once you are done. It has worked fine for nearly a year since then.
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
Problems with HDMI. Screen goes 'blank' whilst playing game. TV claims to be not receiving any signal. play with HDMI cable at back of ps3 and picture returns... Is this my ps3 my HDMI cable or my...
I have the same problem but i changed my hdmi lead for a more expensive one from comet and its fine now! so proberly just a rubbish HDMI lead i bought mine on ebay for £2.99 :-( Not such a bargain.
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 has no video
I would first try changing the inputs if there is an HDMI cable connected the PS3 will detect it and change the output to HDMI. Make sure when you connect any HDMI cables that the power is off on ALL Units that are using HDMI. Connect the cables then power up all units. Change TV and Receiver or Amp to correct HDMI Inputs. On the PS3 go to Display Settings over to the left of the Crossbar. Select output settings and select HDMI and everything after select AUTOMATIC! Then Set your Audio (Also use Auto) and Save by pressing X.  Good Luck!
Apr 29, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Cant acess ps3 Xbar menu,still plays games
it sounds like you haven't set the display settings correctly. turn off your ps3 and try using the red,white,yellow cables (make sure everything is plugged in correctly). if you get a signal, then change the display settings to whatever connection you will use.
hope that helps
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
235 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
