Question about Brother SE-270D Computerized Sewing Machine
Brother ult disney machine
Seems that every xmas it locks up, says safety device on can't get it off said needle bent or thread jam, took it all apart, no thread any where, needle was bent, removed, usually turn off and on it resets but not at mxas,
hand controll will not turn , bobbin unit wiggles and makes noise !!!
help !!!
marty
  • 1 more comment
  • martycb Dec 17, 2007
    that was hateful
    i was taken in , thought you wanted to help
    fugures you would want $$
    why don't you say that up front !!
    marty
  • Anonymous Mar 14, 2014
    I know how to use the allen wrench to tighten the unit that holds the needle but how do i secure the small bent wire that guides the thread just above the needle
  • Anonymous Mar 17, 2014
    Machine froze. Screen said check if needle bent - nope- or see if thread entangled -took thread and bobbin out. Still jammed. Help?
Marty, it happened to me! I figured it out, if you need help, feel free to email me, it is the bobbin carriage was not put it--not the bobbin spool, but the whole carriage. feel free to email me and I can walk you through it! I just saved myself a trip to the repair! :)
pyles_brandi@yahoo.com
Posted on Jan 03, 2008
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
Seems to be out of sync. makes a knocking sound, not catching bobbin thread.
Is the needle in facing the right way? Flat shank to the back.
The knocking sound could be your needle is bent too, have you just had a threading jam up?
I'd remove the needle plate and bobbin and threads, clean everything and oil, put in a new needle, then slowly move the flywheel manually and watch the needle action to see if you can identify where the knocking noise is coming from.
Failing that, I'd say the timing is out, take it to a serviceman. The thread's not locking is usually a good indication of this fault.
Feb 26, 2011 | Brother XL-5130 Mechanical Sewing Machine
I just had this serviced and I embroidered a few items, I thought that it sounded a little loud. all of a sudden the needle broke. I took the bobbin out and there are scratches on the bobbin shuttle, and...
I would take it back and tell them to fix it right. Was it an authorized service center? If, it was there should be no question. As long as you had your needle inserted right, I don't see how it could be your fault.
Jan 02, 2011 | Brother Disney ULT-2002D
What type of bobbin is used for the Brother DIsney ULT-2002D? I see L and A types.
For the price of them - try buying both, then buy more of the one that works best.
Dec 27, 2010 | Brother Disney ULT-2002D
Needle plate ?
Check this link:
http://www.google.com/products?hl=en&q=ULT%202002D%20needle%20plate&um=1&ie=UTF-8&sa=N&tab=wf
Feb 26, 2009 | Brother Disney ULT-2002D
Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Apr 30, 2008 | Brother SE-270D Computerized Sewing...
The safety device has been activated.
It is under warantee for 12 months, so I would recommend you phone the dealer to arrange for them to have a look at it.....if you have any samples of sewing, take them too.
Apr 05, 2008 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
233 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
