Hi, recomendations for a decent book on UK household electrics
I'm an avid, very competent DIYer and am after a decent book explaining household domestic electrical systems in particular lighting circuits & diagrams. It also needs to explain the current regs in terms a normal person can understand pointing out in particular how the law has changed for installations/certificates/what circuits/appliances have got to be on RCD's etc.
Any advice on suitable publications would be great. Many thanks in anticipation of your help.
Howard Reynolds
    Top Expert:
  • Audio Player... Master
  • 48,186 Answers
Go to your government electrical regulations and legislation
next purchase the trade books to learn how and why the circuit is installed in a building
what you are seeking is what an apprentice has to learn in the 4 year apprenticeship
Posted on May 16, 2017
  • 3463 Answers
SOURCE: My Bosch Classixx 1200 washer causes the household RCD to trip
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
Posted on Dec 31, 2008
  • 176 Answers
SOURCE: ::check engine like::E49::
It sounds like you really would like to start repairng cars, and maybe take up being a mechanic for a living....
Check into your local Techincal College for classes..and some high schools that still offer tech classes for cars will teach the students using your pay for the parts..they get the knowlwedge/education, and everybody wins.
Good luck, and Happy New Year
Posted on Jan 01, 2009
  • 2651 Answers
SOURCE: explanation of terms.
corrrect, electric OUTAGE, is a "power cut"or "failure"and a Broil element, is the elemnt located on the top of the inner cavity of your oven, bake elemnt is lower and broil is upper
Posted on Jan 05, 2009
SOURCE: washing machine circuit diagram requested
you all need help
Posted on May 18, 2009
  • 509 Answers
SOURCE: i have fault codes 31 and 42,42 was explained as
31 is throttle position sensor, 42 is Idle switch
Posted on Jan 05, 2010
Won't heat
Maybe the heating element has gone. Replacement ones should be available. Not too difficult to replace and any competent DIYer should be able to do it if the engineers prices are too high.
Jul 23, 2015 | Amana NED5100TQ Dryer
1999 chevy s10 four wheel drive 4.3v6pickup wont pass smog fault code p1870 they said transmission is bad can someone explain what it is
DIYer? I recommend a repair manual from your auto parts store. It should provide a complete list of all error codes and likely repair methods. Otherwise find a competent repair shop, or your dealer. I googled your error code This is just one of the answers:
I am sure you can do a better search since you know far more about the issues.
May 07, 2015 | Cars & Trucks
Ignition light stays on ,i disconnected bat for 15 min but still comes on
Stop by a auto parts store, they may read the error code and tell you the needed fix if you are DIYer. Otherwise, see a dealer, or competent repair shop.
May 05, 2015 | 2005 Ford Ka
Won't blow hot hair
You can use the attached website to get information on your dryer. You will need your make, model, and serial number. You should be able to find a video to help you understand how your dryer heating system works and what parts could be causing the problem. This can be a very technical repair. Do Not Attempt if you are not an avid DIYer or able to understand the directions for the repair. It can be very dangerous if you don't correctly complete this repair.
Nov 23, 2014 | Maytag Dryers
I can move the basket all around up and down back and forth by hand it is lose
I bet it sounds like a jumbo on take off when its on full spin, sounds like the drum bearings have gone. Quite a big job to replace but not beyond a fairly competent DIYer. Go to
you'll find a very good video that shows you how to change the bearings (assuming that's the problem) I managed to sort mine using this video.
If this helps please remember to rate me
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi WFL 2450UK/12. Getting very noisy on spin. Suspect Drum bearings. Is the jib do-able be a competent (me)!! DIYer. If so is there any guidance on the airwaves. VMT Simon Hambrook
you can find an answer on utube ..It is quite a hard job if you are good mechanicly the give it a go, Failing that call an engineer.Good luck.
Feb 08, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Hill decent control and Traction control lights
These landrovers have a lot of Electrical faults.The first thing i would recomend is to change the switch.Has this is the cheapest option.Hope that works for you.
Nov 08, 2009 | 2002 Land Rover Freelander
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
On-line training
I think the software has been discontinued by Sony. Sony came out with another product line that competes with Avid/Pinnacle Systems, and Adobe called Vegas Movie Studio. It's more of a professional video editing system but has starter options as well so that later more features can be added for professional video editing such as chroma key and audio editing.
Image Mixer was creating videos in MPEG1 format while most video editing systems create MPEG2 and/or MPEG4 which are better quality formats to work with DVDS, IPods, and You Tube.
Vegas does have manuals available at book stores to support further training as well.
Aug 08, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
125 people viewed this question
