Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The picture seems to be cropped. Some graphics on
The picture seems to be cropped. Some graphics on the outer edge are partial words suggesting I'm not seeing the entire frame.
  • 834 Answers
Go into your customer settings and set your aspects or zoom
Posted on Sep 25, 2009
Booklet margins being cropped
You don't need the original HP install disc. Go to the H Support site and download and install the newest one listed for your operating system. Turn the printer off and unplug it, wait 10 secs and plug it back in after installing the latest driver and software. Should work fine for you.
Oct 13, 2014 | HP LaserJet 1200n Printer
After cropping and saving a picture, how do I revert it back to the original photo?
Hello Karen,
You need to go to the original picture file. As you can only undo cropping or other changes while the undo option in edit menu is active, usually early on when file is open in programme editing with. Just after doing the cropping.
So hopefully you didn't crop picture then write over its original file. You saved it { save as } to a new file. If you did overwrite original file after cropping; then you will need to relocate this original picture from the source it came from to access original composition, size etc. If from your camera then simply re transfer to your computer & open it there.
If you're not sure about where it is on your computer then you can do an open search by typing in part of the file name or file format { part after the dot in filename & go through the results lists to try & locate it.
Hope this helps.
Dec 18, 2012 | Microsoft Digital Image Pro 10
How to enlarge/reduce photo size & maintain proportions
I think you are referring to "crop".
After pasting the picture in MS Word,
You would see "Picture Tools" top tab. Then under "Fomat" you would see "crop" click on it and try editing your picture.
It should reduce the size of your picture and maintain the normal image size.
Hope this helps.
Thanks,
Jul 17, 2011 | Microsoft Office Word 2007 Full Version...
I have a canon sd1200is. When I take a photo and look at the screen, the pic looks great. Plenty of space around the person. Then I get it developed at Walmart one hour and the person is so zoomed that...
Try getting the picture printed someplace else. Most likely it's getting cropped in the printing process.
You can also point this out to the staff at the Walmart and request that they not crop your photos.
Oct 17, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
How can I copy image on microsoft word and also edit
Locate the file in the folder.
Right Click on the file name
Left click on COPY
Now open the microsoft word , get a balnk or existing document.
Click on PASTE
You can also use the Insert command in microsoft word to insert a picture.
After getting the image, you can change the size. For any major editing, you need a photo editing program. If you click on the name of the file, you can see any photo editing programs are installed in your computer.
luciana44
Jan 24, 2010 | HP Officejet 4355 All-In-One InkJet...
What versions of 'picture it' has the cutout tool
I see you are using Picture It! 10. I just upgraded from 7.0 which had the cutout feature. This one allows you to make a cutout but it is a process.
Here are the directions on the help page:
To create a cut-out:
  1. Make sure the StackThe palette in the workspace that shows the layering order of objects. appears in the workspaceThe grey area that surrounds the canvas..
  2. On the Stack, click the object you want to make a cut-out from.
  3. On the workspace toolbar, click one of the following selection tools:
    • The marquee toolA tool that helps you select part of an object in the shape of a rectangle, circle, or other shape. This tool is useful for cropping objects or pictures to a standard shape. marqueetoolbutton.gif
    • The freehand toolA tool that enables you to make a selection by drawing on the canvas. freehandtoolbutton.gif
    • The Edge FinderA tool that enables you to make a selection by tracing along the edges of an area in the picture. edgefinderbutton.gif
    • The Magic WandA tool that enables you to select areas of similar colour simultaneously. magicwandtoolbutton.gif
  4. On the picture, use the selection tool to make a selection.
  5. On the Edit menu, click Copy. arrowblueright.gif Optional: Switch the background picture.
    1. On the Files paletteThe palette in the workspace that holds all currently opened picture files. click a picture. The new picture is opened on the canvas.
    - or -
    1. On the File menu, click Open.
    2. Locate the picture you want, and then click OK. The new picture is opened on the canvas.
  6. On the Edit menu, click Paste. The new object is pasted on the canvas, and it shows up as a new object in the Stack.
Note
If you paste the new object into the same picture you copied it from, it will blend in with the background picture until you move it or resize it.
Tip
You can soften the selection with the anti-aliasA selection option in which the pixels along the edge of a selection can be partially selected. In most cases this makes the edge of a selection appear smoother. or featherTo soften the edges of a selected area by smoothing the transition from selected to non-selected pixels. option, which helps the new object blend in with a new background picture.
May 09, 2009 | Microsoft Picture It Premium 10 for PC
Dispaly of E:62:12 on display sceen
It is not a setting, it is an error message telling you that the camera is damaged
Jun 23, 2017 | Sony Cyber-shot DSC-H7 Digital Camera
I have a 10" frame. The picture that I take with my digital camera is cropped by the frame. It seems to crop about an inch off the edges. How can I fix this. I can alter the picture if necessary.
Depends...
if it's during a slide show, then there's a slide show option "screen fit or fill".  If you are set to fill then it will cut off edges, change the setting to screen fit.
or if it is cutting off all 4 sides when displaying a single photo, you may have the zoom turned on.  Tap actions / zoom and set the zoom back to 1x.
Dec 15, 2008 | Kodak EasyShare EX1011 Digital Picture...
Partially dark screen
this sounds like a loose connection of your LCD back-light called the display inverter. squeezing, with your hand, the outer edge of the frame (NOT SCREEN) on the side affected could conform this.
Sep 22, 2007 | Acer Aspire 5100 Notebook
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
