Question about Woods Garden
Model 350447 type 1118-A1 code 96121911 my starter turns and makes noise, but doesn't turn the engine --- won't start
  • 62 Answers
This Briggs engine has a plastic bendix gear on the end of the starter that maybe worn out. You can replace just the bendix if everything else is ok
Posted on Sep 25, 2009
2001 jaguar s-type won't crank battery new and charged. Turn the ignition car won't make a sound
many things will cause no start problems could have faulty ignition switch.use test light see if power going to starter if not check ignition fuse to starter.if power going to starter, more likely starter solenoid or starter faulty.if ignition fuse okay and starter and solenoid okay still no start problem could be in the ignition switch or inhibitor switch faulty.code scan for faulty theft security system which will also cause no start conditions.
Oct 22, 2012 | 2001 Jaguar S-Type
Car won't start and starter is only making clunking noise
You can take out the spark plugs, keep track of your spark plug wire order, try to crank it over see if the engine turns over.
Check voltage on your new battery, some need to charge when new.
check for corrosion on the battery and starter cables.
Sep 29, 2012 | 1991 Saturn SL1
Ford contour wont start
You need answer some questions first to rule some things out.
Is the starter making a noise when you turn the key or is it just clicking? If the lights light, but the starter makes absolutely no noise, then the power cable to the starter is bad or contacts are corroded. If you hear a click every time you turn the key but that is all, then the starter is bad and needs replace. Once it is removed, most parts stores can test it for you. If you can hear the starter spinning but its going real fast then again the starter is bad. If the starter is working properly (like on a really cold day when it doesn't start right away) but the car still won't start, then the starter is fine and your problem is either in the ignition or the fuel system. You may be able to narrow it down if you can read the codes, otherwise it needs a mechanic and you need to decide what is the car worth to you.
Sep 17, 2012 | 1998 Ford Contour
Won't start
Switch on head lights or cabin light. If they doesn't come on or is weak, the battery is flat. Ensure that you switch off the lights.
With ignition switched on, assuming the lights on the instrument panel cames on and your immobiliser is deactivated, turn ignition to start. You should hear the solenoid at the starter making a click sound. If not, the battery is flat or the starter solenoid is faulty. If it does make a click sound, the battery could be too low to turn the starter or the starter is faulty. Assuming the immobiliser is working correctly, and the starter tries to turn the engine but it doesn't want to turn, the gasket could be blown and the cylinder filled with water, or the engine could be seized.
Hope it is not the last case. MarioCpt
Mar 06, 2012 | 1999 Toyota Corolla
I have a 2002 Chrysler town and country. I just put in a new battery 3 weeks ago and they checked the alternator and said it was fine. Now it won't start. When you turn the key the radio and lights...
I hate to say this to you but make sure the engine is not locked up. If you can turn the engine, either by pulling on the belt, or by putting a wrench on the crankshaft bolt, try another starter. If you can't turn it, try another engine. (sorry for the insensitive attempt at humor)
Aug 17, 2011 | 2002 Chrysler Voyager
My car will not start my lights, radio work its not the battery. I recently replaced the starter, the altenator, battery, fuel pump catalyic converter. when i turn the key there is no noise it won't...
Sounds to me like the starter or starter relay, OR did you check all the fuses? When the starter doesn't click or turn over the engine it is likely a problem with it or the power supply to it. Start with the easy thing. check the fuses, then the relay.
The P0300 is usually caused by something other than the spark plugs or coils. A fuel/oxygen sensor can cause this code. I would say that doesn't have anything to do with not starting.
Good luck.
Thanks for using FixYa.
Gaker
Jul 22, 2011 | Ford Expedition Cars & Trucks
Car will not start, just makes a whirring noise when I try to start it,the check engine light comes on.
There is most likely a problem with your starter -- if it is not grabbing the engine to turn it over when you turn the key, the starter motor will spin (giving you the whirring noise) but the engine will not move. First things first ... have someone turn the key, and hit your starter with a stick or something ... sometimes this will free up whatever part is not working proper5ly, and you won't have to replace your whole starter. If hitting your starter doesn't work ... and if you are good with cars, try replacing the starter and see if that helps.
Hopefully those will help ... if not, you will probably have to take the car to a mechanic to get it fixed, as there are several other parts that could be causing the issue -- but they are hard to get to and require some experience to know what you are looking for.
May 29, 2011 | 2004 Chevrolet Cavalier
Hello, my LGTH2454 has been running fine. It sat for about an hour then I went to start it and the starter engaged on the flywheel but won't turn. I took the starter off and tested it. It seems to...
Sounds to me like the battery hasn't enough charge to turn the engine. Taking the starter off and testing it doesn't require much power as it doesn't have to turn the engine. Check the battery and also that the charging system is charging the battery back up. Alex.
May 20, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Garden Logo
81 people viewed this question
Top Woods Garden Experts
D. E. Hev
Dennis Key
Dennis Key
Are you a Woods Garden Expert? Answer questions, earn points and help others
