Question about Pride Health & Beauty
Chair goes real slow - Pride Health & Beauty
    Problem Solver:
  • 6 Answers
The battery may not be fully charged or it may possibly be getting near the end of its battery life
Posted on Sep 25, 2009
Chair surges fast/slow
There is no real way to clean the switch, you need to replace it.
Aug 11, 2016 | Invacare Pronto M41
Pride z chair goes forward very slow, no speed but turns faster . whats wrong?
The Brakes could be hanging up causing bad drag on the system. The Joystick gimbal maybe wearing out. The programmer may need adjustment, but I would look at the brakes first. Strege Mobility
Apr 28, 2016 | Pride Jazzy Z-Chair Z-CHAIR
I have a pronto m6 , I replaced the batteries and it will move and turn ok but is real slow and no power .
Test the battery voltage at the joystick where a programmer or charger would plug in. There are 3 holes, the top or number one hole is the positive hole for a voltage meter to plug into and the bottom or number two hole is the negative hole for the volt meter. Plug in the meter and see what the voltage is when sitting still and keep the meter in and see what the voltage does while you are driving the chair. The voltage should not drop more than 1 or 2 volts from that which you had when the chair was not moving. If the voltage drops more than that then there is a problem with charging or the new batteries. If the voltage remains good then the joystick or speed knob control could be the problem.
Apr 26, 2015 | Invacare Supply Group Pronto M61 Standard...
My son has a invacare chair should go 6 mph but has slowed to a snails crawl. How Can I speed it back up?
The chair may be in what they call SLOW MODE or the batteries are weak. If you have powered seating on the chair the seat has sensors that make the chair drive slow or not drive at all when the seat is tilted or reclined or raised. A sensor can go bad or get out of position. The joystick could have different programming for different drive modes. Try changing drive modes.
Jun 11, 2014 | Invacare Supply Group Pronto M61 Standard...
Invacare m51 runs out of power to soon. Green power light never goes to amber just runs out of power to soon warning light never goes to amber. just runs out of power
This is most likely a case that the controller/computer(the box that the joystick plugs into down inside the chair)is placing the chair into what is called a "limp-home" mode. It automatically senses something seriously wrong with the chair and starts cutting the power to the motors, such as overheating. If they are still getting hot, it will shut itself down completely, and you can restart after all cools down, but you have a serious problem on your hands. This usually happens when a chair is loaded near or past its maximum weight, and say you try to drive it up a long incline....motors will overheat and it will slow down, then shut down. If it is doing it on a flat surface without being heavily loaded, you have motor problems or controller problems.
Apr 21, 2014 | Invacare Pronto M51 Power Wheelchair
Chair is slow on commands
Try Home Meridian parts.............
Apr 01, 2014 | Home Meridian Comfort Lift Recliner
Go Chair goes slow
check the breaks are not sticking on.
slacken off or remove to try if this is the fault
Jun 02, 2013 | Pride Mobility Pride Go-chair Travel Power...
Help I stupidly got my dog lead caught around the left drive wheel of my M61 Pronto yesterday. A kind person got it unwound but needed to tip the chair on its side to do it. Now the far left single green...
The M61 has an elevating seat. There is a speed limit switch which consists of 2 magnets that make contact under the seat on the seat post. If the 2 magnets are together then the chair thinks the seat is all the way down. If the magnets aren't touching it activates a safety feature in the controls which cuts power to the chair by 50% hence drives real slow. Try lowering the elevating seat down through the joystick controls. If that doesn't fix it then either the magnet switches on the seat post came unplugged or broke.
Sep 16, 2011 | Invacare Supply Group Pronto M61 Standard...
Shows full charge,goes ok for a little while but then stops turn off then on goes very slow for seconds then stops again.
Hi Susan, I repair power wheel chairs, Its possible that your chair has a bad battery on it , all p/chairs have 2 batteries.And even though you show a full charge one battery may have a bad cell in it you need to get both batteries load tested . I think you my find one of them bad. take them out of chair and have them tested.You can get replacement batteries , and have yours tested at a store that sells batteries only, look in yellow pages for a battery store . Good luck, Erik
Mar 01, 2010 | Electric Mobility Shoprider Electric Power...
Reverse speed too high
No, the controller must be reprogrammed and you will need an Invacare service tech to bring his hand-held programmer over to make the corrections to the chair.
Oct 11, 2009 | Health & Beauty
Health & Beauty Logo
75 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
