Question about KitchenAid KHWS02R Front Load Washer
Control locked light is on and washed wont respond as it is locked. What is the procedure to follow in order to get the washer working again. (KitchenAid front loader)
    President:
  • 1,015 Answers
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Posted on Sep 25, 2009
Washer does not respond to control
Hello Walt;
My name is Peter. I am a retired field service appliance technician.
Maytag makes a good unit. Please give me more information. Is it a clothes washer or a dish washer?
Please provide the model number so I can see what you have.
These numbers are on the machines, usually after you open the door you will see a name plate.
1.) Do you have power? Does the control panel light up?
2.) There are several reasons your unit may not respond to the control.
a.) A faulty door lock switch will lock out your control.
b.) Both clothes and dish washers have thermal fuses. These too will lock out your control.
Once again send me your model number and more detail & I will help you.
Peter Goodwin
Glen Burnie, MD
443-306-1362
Jan 13, 2015 | Maytag Washing Machines
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front door wont close control locked light is on
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The machine's "Control Locked" light is on.
Did you try to push and hold the 'CYCLE END SIGNAL' button for 3 seconds?
May 02, 2010 | KitchenAid KHWS02R Front Load Washer
Control locked
The following link explains how to correct a Control Lock problem on a Whirpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If these procedures do not correct the error, you may have a more serious problem. If you need further assistance, please let me know. I hope this helps you.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The control locked light is on. washer won't come
If these procedures do not correct the problem, you may have a more serious problem. If you need further assistance, please let me know. I hope this helps you.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Control Locked light is on...
OMG!! I just held the button at the end of cycle signal for about 3 seconds and the light went off! Now my washer is working!
Ok Yankee
Nov 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid KHWS02R Front Load Washer Logo
229 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
