SOURCE: HP Officejet 7410 AIO keeps saying out of paper when plenty of paper loaded
Once remove both the trays and insert them again and if the problem persists, power cycle and semi-full reset the all-in-one.
SOURCE: ricoh 2022sp internal tray 1
Where the paper comes out there is a little black thing that is supposed to stick out. Somebody has pushed it in.
SOURCE: Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn /
3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn
/ 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's
operator panel, perform the following steps:
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure
1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator
Panel
To verify the paper type matches the type set in the printer's operator
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the
MPF only.
Verify the printing preferences on the Dell™
3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with
the correct paper size, perform the following steps:
The Printers and Faxes
window appears.
The
Printing Preferences window appears.
This sets the size and tray
defaults.
Verify the Paper Size From the Printing Application Matches the Designated
Printer Tray
To verify the paper size from the printing application matches the designated
printer tray, perform the following steps:
Verify the Paper Source From the Printing Application Matches the Designated
Printer Tray
Do not replace any printer hardware as this is not a printer hardware
issue.
SOURCE: paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
SOURCE: Ricoh Aficio AP410 paper tray
Try this links for the parts of Ricoh printer:
Ricoh USA
The Printer Place
Thanks
Scott
