Question about Hitachi 1TB External USB 2.0 Hard Drive
Computer doesn't detect drive
I plugged in my Hitachi 1TB USB External Hard Drive into my computer but it doesn't detect it. It has power and it sounds like its "thinking", making a buzzing noise every once in a while, and the red light in the front is fading in and out.
  • 6,831 Answers
Hello
I had this problem a few months ago and i fixed it by following this steps.
Go to control panel.
Administrative tools.
Computer managment.
Storage.
Disc management.
Right click on you drive in the chart
Click on change drive letter
Change
Restart your computer and it should work.
Please rate this.
Best regards
Posted on Sep 25, 2009
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
Used drive once, now computer doesn't see it
try restarting computer with drive plugged into usb but no power on drive
once computer is all on, then power on the hard drive
May 24, 2012 | Freecom Xs External Usb Hard Drive 1tb
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
Hallo. My simple drive hitachi 1TB 96300-41001-170 dont appear in my computer. I need driver but i cant fint it.
This should be plug-n-play. Have you tried restarting the computer with the hard drive plugged in? If that doesn't work, I would return it.
Apr 14, 2011 | SimpleTech 1TB SimpleDrive Pro Duo...
My external has stopped working- it also has an odd sensation when I pick it up rather like two identical magnet ends being held together. I only bough it 4 months ago and want to get the data from it!
is the issue a power 1 or does it power up but your computer doesn,t regonized the harddrive within the external...have you tried a separate power supply/usb cable....or try a different usb port in another computer
regards Tony
Mar 31, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
Hi i'm from greece and i bought a hitachi simple drive external hard drive 1 tb about 4 months ago it worked fine but now suddently it stopped . i tried to take it of the power and i also removed the cable...
you must have short in the wire hooked up to external try jiggling the base of wire pluged up to port on the external see if you see the light on hard flicker on off if thats the case its your wire for right intell you get a new wire prop something underneath wire intell you see the light stay on.
Feb 24, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
Hardisk is not detcted on any computer
1.check the USB cord
2. the controller to the USB drive could faulty.
3.the usb port could be damaged / try another port.
***I hope this helps. Have a great day!***
Jul 10, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
Problem with Hitachi 1TB external hard drive
Most likely you just burnt up the adaptor. You can order another one from Hitachi.
The data is probably still intact on the drive itself.
You can connect it to your computer with an adapter that plugs into the drive itself and the usb port on your computer. It then shows up as a drive letter as normal.
You can buy these sata to usb adapters at most computer stores for around $25. Tiger has a nice selection:
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=sata%20to%20usb%20adapter
I would pick one with an external power supply. It also connects to your hd. The ends are keyed so you can't miss-plug them.
Or find a local computer tech (most have this cable in our toolkit) and he probably will copy your data in a few minutes for you.
Sep 04, 2008 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi 1TB External USB 2.0 Hard Drive Logo
1,583 people viewed this question
Top Hitachi Computers & Internet Experts
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
