Question about Epson Stylus Pro 3800 InkJet Printer
Inconsistant printing I have a Hp color laserjet 2500l and it's only printing on some of the page. I changed out the toner and that didn't help. What else should I try???
2 Suggested Answers
tigertail
  • 163 Answers
SOURCE: Cyan toner problem
Is the section that is not printing down the r/h side of the page?
If so then it is likely that one of your toners is not "locked" in fully. Open the top panel, lift up the orange lever and pull out the PCU. You can now rotate the cartridges, check each one is fully locked in by the coloured levers on the r/h side. Even if one is slightly raised it will block the path of the laser and cause the symptoms that you describe.
Please take a moment to rate this solution. Thanks.
Posted on Mar 08, 2009
Hp laserjet 2550n stopped prining in color, why?
Check your print driver settings. And if you are printing from any of the microsoft office applications look at the page setup to see if something was changed. Click file, then right near print is the page setup.
Nov 21, 2011 | HP LaserJet 2550n Printer
I changed the drum to my HP LJ 2500L and now ot only prints in black and white. I have triple checked it's the right drum and there are no errors showing up. What's the problem?
Print a Configuration page, if it is grayscale, you probably installed a bad drum.
Make sure that "color" mode is selected in the program you are using or the printer driver. Check and see if "grayscale is selected.
If you are printing transparencies, they ONLY print grayscale.
Go to hp.com and download the latest drivers.
Apr 05, 2011 | HP LaserJet 2500L Printer
Hp 2500l prints a dark line horizontal down each page. Can we clean drum at home?
A dark line on the hp 2500 series can come from the drum You can't clean it at home), it can come from a toner cartridge, from the fuser unit and from the optics.
Step one - check if the line in all colors, run copy quality check through Menu and diagnostics, if the line is only on one color your problem is the toner cartridge.
Step two - if the line is on all colors, take the drum unit out and look at the drum, if you see the line on the drum you need to replace the drum unit.
Step three - stop a print in during the printing process by turning the printer off, take out the drum and look at the printed paper under the drum, if the printed page is clear of line your problem is in the fuser.
Good luck.
Dec 14, 2010 | HP Color LaserJet 2500L Laser Printer, up...
My HP color LaserJet 2500L printer will only print yellow or black. All the toners are good and the machine has been re-calibrated and cleaned but it will not print full color
Print cartridges might be improperly installed. Remove the print cartridge for the color that is printing inconsistently and reinstall it. im sure you tried this already, but thats from the manual. also check your settings in the computer verify greyscale is not selected. also. Re-calibrate anyway To calibrate the printer from the HP Color LaserJet 2500 Toolbox 1 Open the HP Color LaserJet 2500 Toolbox in one of these ways: • On the desktop, double-click the HP Color LaserJet 2500 Toolbox icon. • On the Start menu, point to Programs, point to HP Color LaserJet 2500, and choose the HP Color LaserJet 2500 Toolbox. 2 On the Troubleshooting tab, click Diagnostic Tools (on the left side of the screen). 3 Click Color Calibration. Then try a test page. if all else fails Try this The NVRAM reset is done by powering off the machine. Press and hold the Go button. Turn the printer on and continue to hold the Go button. After the Go, Ready, and Attention LED's tuirn on, continue holding for at least 20 seconds. During this process, the Attention, Ready and Go LED's will each turn off. Release the Go button. The device LEDs will begin cycling from front to back. The NVRAM init process runs unitl the printer is in the Ready state.
Aug 27, 2010 | HP LaserJet 2500 Printer
I have a HP laserjet 2500L printer, when I try to find out the status of my supplies, by going to Toolbox/device/information. I get an error message "can't find server" I have uninstalled/reinstalled the...
you can print out a status page by holding down the green button untill all lights flash than let go..( this will than print out a config page showing your supplies status..
Jan 30, 2010 | HP LaserJet 2500L Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Will print in grayscale only not in color Vista
Find printing preferences and there will be value to change print it color or greyscale. Printer preferences can be find in control panel>printers default printer menu (right mouse on default printer).
Jul 30, 2009 | HP Color LaserJet 2500L Laser Printer, up...
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Epson Stylus Pro 3800 InkJet Printer Logo
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
