Question about Maytag Dryers
Dryer won't start
When you push the button to turn on the dryer, all it does is click.
  • Maytag Master
  • 7,482 Answers
Take a look at the motor and see if it is running.
If it is not, then the motor could be your problem
If it is running then you want to see if the belt has come off the pulley of the motor or maybe the drum belt is broken.
Posted on Sep 26, 2009
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
Everything lights up, but won't start when start is button is pushed. Lights turn on when door is opened.
There are 5 possible causes for this. Click here for the Service Manuals=> Trouble Shooting Guide and click here=> NGD7200TW Parts List and click here for your user manual=>NGD7200TW User Manual
For any Whirlpool Related manuals please contact me=> HERE Need Adobe Reader? Click Here sea_breeze_3.png
I will be here should you have other questions, Thanks, Sea Breeze
Aug 31, 2011 | Amana NGD7200TW Gas Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My Kenmore dryer won't stay on when you push the start button it starts and turns off real quick. I have gotten new fuses and replaced them and it still won't work.
heatman101
Jun 01, 2011 | Dryers
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Won't start just clicks when i push the start button. When I push the start button I do hear a faint click in the selection ( color, white.etc.) button
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Mar 05, 2011 | Kenmore Dryers
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
